Timbo
Post by Timbo on Oct 4, 2016 16:32:01 GMT -7
dynaguy
Post by dynaguy on Nov 14, 2016 13:48:59 GMT -7
Hi Timbo: Do you have the noise limiter installed in this video? Also any chance of a "fly by" at some point. Getting ready to pull the trigger on an FZ 10 and want to get mods out of the way from the get.
carlos1989
Post by carlos1989 on Nov 14, 2016 14:59:42 GMT -7
He removed the baffle in this video .
Timbo
Post by Timbo on Nov 14, 2016 17:37:18 GMT -7
Hi Timbo: Do you have the noise limiter installed in this video? Also any chance of a "fly by" at some point. Getting ready to pull the trigger on an FZ 10 and want to get mods out of the way from the get. I have the baffle out in this video. Sorry, can't do a fly by. You will love the Graves. The quality is top notch. Also with the 2weeldynoworks flash you do not need the o2 sensors, which looks a lot better without the bungs. Also, they have fixed the cruise control problem, so cruise works! The flash they have now is from another exhaust. They will be getting a Graves exhaust to tune with, so the tune will be better. I just installed the ActiveTune autotune unit from Flash Tune, which will even fine tune it better on the go. Haven't got to ride with it yet. Also you need to install block off plates.
dynaguy
Post by dynaguy on Nov 15, 2016 12:58:05 GMT -7
Great info. Plan to go with the Graves Cat Eliminator, block off plats and 2Wd reflash. Those mods along with a Vagabond tail eliminator kit should do the trick. In the meantime, I'm enjoying the forum and learning a lot.
