techsniffer
Post by techsniffer on Mar 29, 2019 16:52:48 GMT -7
While I'm not yet sold on getting some risers, I want to know what my options are and I'm having a bit of trouble finding options, even the parts guy at my dealership isn't having much initial luck, but he said he'd look into it more this weekend. I am looking for risers that will raise the bars by an inch-ish and what few options I see either don't have any measurement specs or are an odd design I don't really care for at all. I'm hoping to tap into other's research and my searching of the forums hasn't given many results either. I'll list below what I've found and my thoughts, can anyone else offer some suggestions? 1. tstindustries.com/gilles-tooling-adjustable-bar-risers-yamaha-fz-10-mt-10-2016.html - I can't find any information about the total height and forward/back adjustments, It only lists the increment amount it adjusts so, in the end, I have no idea if it's shorter or taller than stock risers. I don't mind the look, but not sure I really need that level of adjustment. If this post is correct, then it's max height is same as stock. 2. roxspeedfx.com/collections/adv-dual-sport-dirt-bike-handlebar-risers/products/2-pivoting-bar-risers-for-1-1-8-handlebar-with-extended-stem?variant=1187894161 - I greatly dislike this method of piggybacking from stock riser to new riser, I think it looks sloppy and half-assed. And I think the overall height would be such that would lead me to have cable length issues. I haven't found really any other options, I did find a DIY solution that I might consider if all else fails, can't be more expensive than some of these options. Hoping someone might have some more info than I can find. Thanks!
jgonzo
Post by jgonzo on Apr 28, 2019 12:53:57 GMT -7
This is what I did. Not my idea but worked excellent and cost me maybe $25. Had to remove the stud from the stock risers and pick up some bolts to replace them at the proper length. Plan on spraying them aluminum color to match but wanted to see how I like them before I added more time to the project.
techsniffer
Post by techsniffer on Apr 28, 2019 13:16:51 GMT -7
Yeah, I was thinking about this being my only option since the stock risers are already so tall no aftermarket ones go farther up. I'll check with some local machine shops to see what it will cost me. I assume you only did an inch rise?
jgonzo
Post by jgonzo on Apr 28, 2019 13:31:03 GMT -7
Yes, 1". Released all cable clamping to make sure moved freely before re-attaching. No issues. Any higher and I think you'll probably get some 'length issues'.
superspirit
Post by superspirit on Apr 29, 2019 14:11:58 GMT -7
Nice, I like ideas like this.
wyand69
Post by wyand69 on Jun 19, 2019 6:04:45 GMT -7
Yes, 1". Released all cable clamping to make sure moved freely before re-attaching. No issues. Any higher and I think you'll probably get some 'length issues'. You wouldn't happen to have the exact dimensions on those risers with you. Really thinking I'm going to do the same exact thing
jboy
Post by jboy on Aug 12, 2019 16:56:22 GMT -7
At 6-2, I was also looking to raise the bars about an inch, couldn’t find any risers so I started looking at handlebars. I found these adventure bars from pro taper and I am happy with the results. They have slightly more sweep but are very comfortable
jboy
Post by jboy on Aug 12, 2019 17:10:21 GMT -7
Sorry, the pictures won’t load
Post by clayton on Aug 12, 2019 17:14:09 GMT -7
Sorry, the pictures won’t load Would love to see them! What model are they? What color? Did the cables and brake lines work with them? Are you on the Facebook mt/fz10 page and could post pics there?
jboy
Post by jboy on Aug 12, 2019 18:10:31 GMT -7
I put a picture at mt/fz10 FB page. In the visitors posts.
Post by clayton on Aug 12, 2019 19:34:49 GMT -7
I put a picture at mt/fz10 FB page. In the visitors posts. I could not find it. Ca n u post link to it here. Thanks
jboy
Post by jboy on Aug 12, 2019 22:17:49 GMT -7
picture here ( I hope). There are 2 heights available in the adventure bend, these are the lower version
travist67
Post by travist67 on Aug 13, 2019 10:06:56 GMT -7
Yes, 1". Released all cable clamping to make sure moved freely before re-attaching. No issues. Any higher and I think you'll probably get some 'length issues'. Can you please let me know where you got those spacers? Thank you.
kristianmartin
Post by kristianmartin on Aug 14, 2019 10:20:17 GMT -7
Did you make those, have them made, or buy them somewhere? I'm very interested in trying this out. Thank you!
techsniffer
Post by techsniffer on Aug 16, 2019 7:45:22 GMT -7
Not yet, most shops I contact locally will only do batch orders (like very large batches) and not one off things like this. Its still on my list
travist67
Post by travist67 on Aug 17, 2019 4:32:32 GMT -7
I ordered a set of Rox risers from revzilla. I'll post up to let everyone know if they fit/look good or don't work at all. I did the online chat with their support before ordering and they said they could not guarantee they will fit but that I can return them if they don't so I figured I'd give it a shot. Stay tuned.
techsniffer
Post by techsniffer on Aug 17, 2019 7:06:33 GMT -7
I went to a custom motorcycle shop and they can do it for me for about $85 for the parts.
Post by hooli on Aug 17, 2019 11:14:15 GMT -7
The bars aren't high enough?
travist67
Post by travist67 on Aug 17, 2019 14:05:21 GMT -7
The bars aren't high enough? It's high enough for some people. And the seat is comfortable enough for some people. And the exhaust is loud enough for some people... See where I'm going with this? I've had a couple of bikes in the past that I installed risers on to give me a more upright seating position. It lets me ride much longer without my wrists starting to hurt and my back feels better when I ride in a more upright position. The bike I've been riding the most recently has risers on it I installed. Very comfortable seating position for me. As soon as I started riding the MT-10 that I just picked up the other day I found myself leaning forward more than I would like to. I'm fairly certain from my past experiences with bikes and risers that installing a set on this bike will make me enjoy the bike even more. I think that's the general idea. It's not that they aren't high enough, it's just that a higher position is more comfortable for some people.
cp3ryder
Post by cp3ryder on Aug 17, 2019 21:09:18 GMT -7
I ordered a set of Rox risers from revzilla. I'll post up to let everyone know if they fit/look good or don't work at all. I did the online chat with their support before ordering and they said they could not guarantee they will fit but that I can return them if they don't so I figured I'd give it a shot. Stay tuned. I installed the Rox 2" risers back in June, you can check them out here: fz10.org/thread/2806/new-member-nh
