gnarleyb
Post by gnarleyb on Mar 16, 2019 14:14:00 GMT -7
Replacing frame sliders with newer ones. Got the old bolt out but now cannot install new bolt. Motor shifted. Any tips to straighten it out?
gnarleyb
Post by gnarleyb on Mar 16, 2019 14:16:56 GMT -7
jroc
Post by jroc on Mar 16, 2019 14:23:50 GMT -7
Use a jack under your exhaust.
redgecko59
Post by redgecko59 on Mar 16, 2019 14:31:03 GMT -7
Replacing frame sliders with newer ones. Got the old bolt out but now cannot install new bolt. Motor shifted. Any tips to straighten it out? Heard of this happening on the R1 but first time on an MT10. You may have to loosen the other engine mount bolts to be able to get it lined up again.
gnarleyb
Post by gnarleyb on Mar 16, 2019 17:04:25 GMT -7
Was able to loosen up it up and use a block with a jack to lift up the engine just enough. Thanks guys
Post by thefinn on Mar 16, 2019 17:08:08 GMT -7
Id say the same. Loosen the engine mounting bolts and let it sit into place again, then tourqe them down again.
This may or many not help, but as long as you dont pull any bolts out, i dont see anything that could go wrong with trying that out.
Have you dropped your bike? This usually puts torsion throughout the bike and you need to have everything loosened up to let things seat themselves in a natural position again. Just like your body needing massage/chiropractic/acupuncture (ofcause after a doctor as given you premission to) to get everything losened back up after comming off the bike, your bike needs the same.
