jharmon718
Post by jharmon718 on Mar 13, 2019 4:47:12 GMT -7
Post by thefinn on Mar 13, 2019 11:32:41 GMT -7
I just cut off the OEM blinkers from the harness and connect the new signals to the connectors wires, then plug in the connector where it was previously. This way (in the case of the rear blinkers) the stock relay even stays on.
jharmon718
Post by jharmon718 on Mar 13, 2019 11:41:15 GMT -7
I just cut off the OEM blinkers from the harness and connect the new signals to the connectors wires, then plug in the connector where it was previously. This way (in the case of the rear blinkers) the stock relay even stays on. I like to keep all wiring untouched do that in the event I need to put it back to stock I just have to plug everything back in. And for only $10 for a pair that's not a bad deal.
Post by thefinn on Mar 13, 2019 14:44:47 GMT -7
Fair enough, personally i just throw anything that comes off right in the recycling bin.
redgecko59
Post by redgecko59 on Mar 13, 2019 15:21:18 GMT -7
I like to keep all the wiring untouched too but I just order the plugs myself and make my own looms. Also those are 2 wire plugs which are no good in the USA as we use 3 wire on the front due to the running lights.
jharmon718
Post by jharmon718 on Mar 13, 2019 15:25:24 GMT -7
I like to keep all the wiring untouched too but I just order the plugs myself and make my own looms. Also those are 2 wire plugs which are no good in the USA as we use 3 wire on the front due to the running lights. Read the post again. Rear turn signals are 2 wire and the front are 3 wire.
redgecko59
Post by redgecko59 on Mar 13, 2019 16:11:57 GMT -7
I like to keep all the wiring untouched too but I just order the plugs myself and make my own looms. Also those are 2 wire plugs which are no good in the USA as we use 3 wire on the front due to the running lights. Read the post again. Rear turn signals are 2 wire and the front are 3 wire. Yeah but the front have the same style plugs as the rear not the ones shown
jharmon718
Post by jharmon718 on Mar 16, 2019 8:47:28 GMT -7
Read the post again. Rear turn signals are 2 wire and the front are 3 wire. Yeah but the front have the same style plugs as the rear not the ones shown I contacted Custom-LED about this today and they said they may be able to help out with making a splitter and/ or pigtails with the correct end on them. If anyone has a picture of the connector for the front signals, send it to me so I can forward it to Custom-LED
redgecko59
Post by redgecko59 on Mar 16, 2019 13:29:11 GMT -7
Yeah but the front have the same style plugs as the rear not the ones shown I contacted Custom-LED about this today and they said they may be able to help out with making a splitter and/ or pigtails with the correct end on them. If anyone has a picture of the connector for the front signals, send it to me so I can forward it to Custom-LED Just tell them they are the same connector as the rear only 3 wire
jharmon718
Post by jharmon718 on Mar 16, 2019 13:30:18 GMT -7
I contacted Custom-LED about this today and they said they may be able to help out with making a splitter and/ or pigtails with the correct end on them. If anyone has a picture of the connector for the front signals, send it to me so I can forward it to Custom-LED Just tell them they are the same connector as the rear only 3 wire I did tell them that. It might appear the same put a 2 pin connector and a 3 pin connector are still totally different.
redgecko59
Post by redgecko59 on Mar 16, 2019 14:03:53 GMT -7
Just tell them they are the same connector as the rear only 3 wire I did tell them that. It might appear the same put a 2 pin connector and a 3 pin connector are still totally different. Not in this case.
