sheffner
Post by sheffner on Jan 9, 2019 18:12:01 GMT -7
New to the forum so I hope I'm posting in the correct place. Anyway 2018 MT10 that has around 2300 miles and I just re-sprung the bike front and rear for my weight. Question is, once I got the bike back together the front brakes feel different than when I disassembled, mostly the travel of the front lever is less and much firmer than it used to be. It also doesn't seem to grab like it quite did beforehand. I have checked everything. Brakes aren't dragging, pads release when lever released. Forks are properly aligned and set at the factory height, (I went as far as using a caliper to confirm). Rotors aren't warped, axle is flush on right hand side. They just feel weird. I guess my question is how much travel does everyone else have on their front brakes? Mine becomes firm right at the second click of the front brake switch just wondered what everyone else had or if anyone else has any ideas? I don't feel like its an air issue mainly because they're really not spongy, actually the opposite, quite firm. I know thats not a bad thing necessarily but the don't seem to grab as well either. Only thing I can figure is I measure fork height before disassembly and found left and right hand side measurements different by about 2mm (this was from factory) so I'm almost wondering if my OCD of getting the exact fork height for both legs had some effect. Any ideas? Or whats everyone else's free play before firm? Thanks in advance!
Post by thefinn on Jan 9, 2019 18:58:52 GMT -7
Not an expert but just throwing this out there
Your calipers might be a little off. Lift the front wheel, loosen the calpier bolts all the way and screw on finger tight.
Spin your front wheel with one hand, and while its spinning grab the brake with your other. Without releasing your grip on the brake, tighten the calipers down with a wrench.
Dave moss has an advanced video on how to assemble the front wheel 100% perfectly:
redgecko59
Post by redgecko59 on Jan 9, 2019 19:21:22 GMT -7
Not an expert but just throwing this out there Your calipers might be a little off. Lift the front wheel, loosen the calpier bolts all the way and screw on finger tight. Spin your front wheel with one hand, and while its spinning grab the brake with your other. Without releasing your grip on the brake, tighten the calipers down with a wrench. Dave moss has an advanced video on how to assemble the front wheel 100% perfectly: I agree with giving this a try, should become your standard practice too.
Post by RedAndBlack on Jan 10, 2019 5:35:32 GMT -7
In addition to above, I would push the pads out back against the pistons. Sometimes the calipers and pistons engage unevenly. Just make sure when you do this, you wedge the opposite caliper with something so you don't close the opposite caliper completely from the brake fluid pressure.
Post by thefinn on Jan 13, 2019 11:40:43 GMT -7
Any updates? Did this work out for you?
sheffner
Post by sheffner on Jan 14, 2019 17:11:53 GMT -7
Unfortunately not. Brakes still feel super weird. Bled them, no air didn't figure there would be. Tried DMT recommendation. no change. I might be overthinking it but they definitely feel different than they did before. Where does everyone else's front lever get firm at? Mine gets firm right at the second click of the brake switch.
Post by thefinn on Jan 14, 2019 18:12:24 GMT -7
Cant get to my bike atm, so cant tell you where my lever engages.
You might want to send them to the dealer to have a look on them just to be sure. That lever is your life insurance afterall.
It sounds a bit as if one of the calipers is blocked completely. That would explain how the lever is firmer (no fluid goes to fill the non functional caliper), grabs earlyer (same reason) and yet braking performance feels reduced.
Try braking somewhat agressively in a safe area and then feel if one brake disc is significantly warmer (please dont burn yourself)
sheffner
Post by sheffner on Jan 14, 2019 18:32:27 GMT -7
I did the hard braking and had friend use my thermal imager camera. Rotor temps are about the same (maybe 5-10 degrees difference). Idk. It’s weird. They felt good before reinstalling the forks but here again the fork heights were off from the factory. I’ve compressed the calipers and slowly reapplied the brakes and both sides seem to grab at the same point (judging where I can no longer freely move the pad up and down). Only other thing I could think of is if the pads wore to how it was from factory and me setting proper fork height, axle alignment etc changed some sort of alignment giving me a firmer feel but less braking. Idk driving me nuts. It’s like I’ve lost the feel to trail brake now that the lever is so firm but doesn’t really slow the bike. I’ve got new pads ordered just Incase they did wear funny but I’m not expecting anything to change.
Post by thefinn on Jan 15, 2019 1:35:51 GMT -7
Sounds reasonable to try that out, if it doesnt help id send it to the dealer to be checked on.
The MT-10 factory brakes arent exactly phenomenal outbof the box, but since youve ridden it before setting the bike up and know how it SHOULD feel, Id brring it in for a checkup. A bike with bad brakes is no fun.
Post by Deleted on Jan 15, 2019 12:06:40 GMT -7
Where does everyone else's front lever get firm at? Mine gets firm right at the second click of the brake switch. Just tried it for you, and mine definitely goes past the second click, and bike is basically brand new (419 miles, with very little brake use). And progressive, like it should be. Sounds like you have a problem indeed, and it's not fork alignment. That behavior makes no sense to me, since you have 8 pistons; even if one was stuck, it wouldn't cause the lever to be hard with so little travel. Did you mess with the master cylinder at all?
Post by thefinn on Jan 15, 2019 12:46:33 GMT -7
Maybe a blockage in the brakeline? But then with my logic, the brakes would also not release immediately when you let go of the throttle. Bring it to the mechanic honestly, rather have someone who does that for a living find and fix the problem than listen to some strangers on a forum who only wrench easy stuff on motorcycles for a hobby Atleast its confirmed that there is something wrong so we got something out of this thread Hell, worst case youll get a perfect opportunity to put on some steel braided lines or even an aftermarket master cylinder for some much needed added brake feel on the FZ-10
Post by hooli on Jan 15, 2019 23:07:19 GMT -7
Here's something you might have missed...it certainly fooled me. Have you double-checked that the marker arrow on your brake lever is indeed pointing at one of the numbers (1-5) and no between them? For awhile I thought that my brakes felt odd. Turned out that the span distance dial was improperly set.
