lastwish
Enter your message here...
Post by lastwish on Jan 2, 2019 9:15:43 GMT -7
I was wondering if anyone's found someone manufacturing hotter cams for the fz10. Not that I'm desiring such a thing but I found it a cool idea, a hotter drop in cam set maybe a gasket too. I've heard of for example, one generation of the speed triple being greatly improved by just such a drop in cam kit. Saw on one of their forums some personal R&D and the forum communities suprise at how much an increase it gave. Obviously not talking about cams in conjuction with super or turbo charging. I'm just curious how much " room " there is to improve on the stock fz10 cams. From what I hear there isn't much.
ghostrider1127
Post by ghostrider1127 on Jan 2, 2019 9:52:45 GMT -7
Well , i was looking into that when i did the engine swap. All mt10 and fz for all mekets got some cams . All R1 (R1S and R1M) got aswel the same cams.(eraly models got another spare part numbers due differences on the valves train) I did not found companies for such hot cams.
Did my own regrinding oem R1
lastwish
Post by lastwish on Jan 2, 2019 14:01:52 GMT -7
That's a LOT of work isn't it? How did you find a cam orofile that gave more performance but didn't damage the engine? Wouldn't that be a lot of research and developement?
ghostrider1127
Post by ghostrider1127 on Jan 2, 2019 15:55:35 GMT -7
Actually i did not got more power but i try flatened out the torque curve and gain low middle grunt like an Mt10 engine but with a bit more power and revs on high rpm
lastwish
Post by lastwish on Jan 2, 2019 21:34:33 GMT -7
Have any dyno charts with the torque curve to share? I'm very curious.
ghostrider1127
Post by ghostrider1127 on Jan 3, 2019 1:31:15 GMT -7
As i personal dynoed did not print , could be i have a copy on PC
lastwish
Post by lastwish on Jan 3, 2019 5:50:18 GMT -7
If you have any charts I'd really like to see them. That kind of stuff is what I really enjoy. I might consider doing something similar.
ghostrider1127
Post by ghostrider1127 on Jan 3, 2019 6:05:36 GMT -7
If you have any charts I'd really like to see them. That kind of stuff is what I really enjoy. I might consider doing something similar. I did the r1 engine swap cause i have two MT10 , sometimes the OEM engine for street use or commuting is way better. If i´m thinking at all the money and the time i spent , well , dunno if i´m gonna make another time something like that........
lastwish
Post by lastwish on Jan 6, 2019 1:43:46 GMT -7
I pondered putting an R1 motor in the fz10 just to have the six-axis IMU, TFT display, the lift and auto launch features along with all the customizable settings. I figured I'd give the final drive a very short ratio to make it closer to the fz-10's torquey and not so top end focused powerband. Or perhaps not, I might like a true superbike engine character in the upright and comfier package. Is that similar to what your motivations were?
ghostrider1127
Post by ghostrider1127 on Jan 6, 2019 2:16:31 GMT -7
I did also a mix of that , no tft display but keeping the IMU and yes you are right i prefer the upright position for street use and commuting.
