ghostrider1127
Post by ghostrider1127 on Jan 4, 2019 7:31:04 GMT -7
I hope they will solve your issue.
redgecko59
Post by redgecko59 on Jan 4, 2019 7:56:33 GMT -7
I don’t think my diagram don’t offer this option. I’ll double check. Thanks I’ve emailed Lightech for brake light connection. Instruction. Although my order was brand new in the last few weeks, maybe they sent me an older model. I’m hoping they’ll do the right thing and offer to replace with the new model that uses the stock brake light switch. It’s totally unreasonable that I should have to mess with my wiring because I chose to buy Lightech. Thanks again They should sort it as effectively they have sent you a set that doesn't work on the bike they say they fit. I wonder if they sent an R1 set? Do you have the exhaust bracket with them?
Post by Deleted on Jan 4, 2019 11:46:57 GMT -7
I’ve emailed Lightech for brake light connection. Instruction. Although my order was brand new in the last few weeks, maybe they sent me an older model. I’m hoping they’ll do the right thing and offer to replace with the new model that uses the stock brake light switch. It’s totally unreasonable that I should have to mess with my wiring because I chose to buy Lightech. Thanks again They should sort it as effectively they have sent you a set that doesn't work on the bike they say they fit. I wonder if they sent an R1 set? Do you have the exhaust bracket with them? Yes they sent their exhaust bracket. It really took some finessing to install though.
ghostrider1127
Post by ghostrider1127 on Jan 4, 2019 12:46:15 GMT -7
It cannot be for R1 as the rear master cylinder got different bolts spacing
saltmarsh95
Post by saltmarsh95 on Oct 4, 2023 3:12:50 GMT -7
It cannot be for R1 as the rear master cylinder got different bolts spacing Did you every get the wiring for figured out ? I’m going through the same issue right now.
