ghostrider1127
Post by ghostrider1127 on Dec 18, 2018 7:22:16 GMT -7
Decided to move on my "standard" MT10 2016 , R1M 17 engined (and at least 35% of stuff is swapped from R1 now) doing a complete tail swap , tail from a R1M rn49 2017 (but also older rn32 models got some unit , even standard versions) What i needed it´s a lot of stuff . (part of it in the pictures) will begin soon the swap .
fz10minesrdripper
Post by fz10minesrdripper on Dec 18, 2018 11:25:42 GMT -7
Can't wait to see it. I was thinking of this, but I want the passenger seat comfortable for my wife. I also have much lower fz09 rear peg mounts and a aftermarket peg lowering kit. When we go for a ride it's real easy to just throw them on. Looks pretty good with them off, but I'm sure your mod will be bad ass. Get it done...we all want to see it.
exuptoy
Post by exuptoy on Dec 18, 2018 12:26:41 GMT -7
I asked a breaker last week and the full kit from a 2016 R1 will cost a £600 in the UK.
ghostrider1127
Post by ghostrider1127 on Dec 18, 2018 13:15:06 GMT -7
Please gave me the address of that breaker....
exuptoy
Post by exuptoy on Dec 19, 2018 0:18:25 GMT -7
ghostrider1127
Post by ghostrider1127 on Dec 19, 2018 0:37:27 GMT -7
I contact them not long ago , but the magnesium subframe had two lugs/brackets broken , that´s a common problem of this item . Another problem it´s the price , as for a new one 1000 are not enough.
nemecham
Post by nemecham on Dec 19, 2018 13:09:25 GMT -7
This is great! I think many of us have been waiting a long time to see exactly what it takes to do the swap. Good luck!
ghostrider1127
Post by ghostrider1127 on Dec 19, 2018 14:21:14 GMT -7
ghostrider1127
Post by ghostrider1127 on Dec 20, 2018 9:50:19 GMT -7
building a correct tank support , and must relocate the rectifier. Tank fairings (side) will be reprofilated
exuptoy
Post by exuptoy on Dec 20, 2018 11:27:49 GMT -7
Well that tank support will be a piece of piss then, you'll also need the seat pan modifying to fit the rear of the tank. Maybe strip the R1 and MT seats and plastic weld in the extended section to the seat pan then re-foam and cover.
I like it.
ghostrider1127
Post by ghostrider1127 on Dec 20, 2018 13:25:01 GMT -7
i already have an idea about the tank bracket , will wait tomorrow for the carbon fiber side fairing and two brackets (rear light and pillion seat )to have all in the right positon to take some measure .
fz10minesrdripper
Post by fz10minesrdripper on Dec 20, 2018 14:59:55 GMT -7
Here's what I'm buying...no pillion seat. It's about 10lbs lighter probably. I'm just kidding...I would just cut off my left arm...it weighs 15lbs. This would save me $1500.00...I can counter steer pretty good with one arm...Ha Ha SE Composites 2015-18 YZF-R1 Carbon Fiber Monocoque Subframe - This unit was used on one of our shop superbikes for 3 rounds and is in excellent condition. Incredibly nice and light. Designed for Lacomoto bodywork, may work with other brands. $1500
ghostrider1127
Post by ghostrider1127 on Dec 21, 2018 4:58:40 GMT -7
Nice piece , i will register also this mod official on paper , so cannot use aftermarket parts without a certification. going on.
exuptoy
Post by exuptoy on Dec 21, 2018 10:01:44 GMT -7
ghostrider1127
Post by ghostrider1127 on Dec 21, 2018 15:00:05 GMT -7
This kind of "tuning" it´s not for me. BTW eletric and abs module sorted today aswel. LI-I= battery also fitted . Will go on with couple of brackets for tidy up the whole . Than tank bracket
Post by Deleted on Dec 26, 2018 23:18:43 GMT -7
Damn, any of us could have done a better job. Ha ha. Send it to Sargent, or somebody else who knows what they're doing. Good luck.
ghostrider1127
Post by ghostrider1127 on Dec 27, 2018 2:05:21 GMT -7
Actually the 2nd pictures was a joke Or you are thinking i will run my bike in that conditions May i will get a corbin with typical doughnut-shaped hemorrhoid pillow Or may not....
Post by hooli on Jan 4, 2019 23:58:31 GMT -7
ghostrider1127
Post by ghostrider1127 on Jan 5, 2019 2:02:19 GMT -7
