Post by Deleted on Dec 8, 2018 10:12:43 GMT -7
Ive installed my new Akrapovic link pipe and slip on and I was wondering whether anyone knows whether there is a removal BD KIller / Baffle in the can and how to remove it? Thanks so much for your help
panzer716
Post by panzer716 on Dec 9, 2018 9:08:47 GMT -7
Ive installed my new Akrapovic link pipe and slip on and I was wondering whether anyone knows whether there is a removal BD KIller / Baffle in the can and how to remove it? Thanks so much for your help If you're wondering about a baffle because the exhaust is still pretty quite, as far as I know that one does not have a baffle. (I have that exhaust) the cat is where all the noise reduction happens so the bike won't get any louder unless you get the link pipe (which I also have). If you do the link pipe you will hear a noticeable increase in volume. That slip on is just a straight pipe from the cat.
Post by Deleted on Dec 9, 2018 9:40:15 GMT -7
Ive installed my new Akrapovic link pipe and slip on and I was wondering whether anyone knows whether there is a removal BD KIller / Baffle in the can and how to remove it? Thanks so much for your help If you're wondering about a baffle because the exhaust is still pretty quite, as far as I know that one does not have a baffle. (I have that exhaust) the cat is where all the noise reduction happens so the bike won't get any louder unless you get the link pipe (which I also have). If you do the link pipe you will hear a noticeable increase in volume. That slip on is just a straight pipe from the cat. I do have the link pipe as well. Thanks for letting me know
panzer716
Post by panzer716 on Dec 9, 2018 9:48:55 GMT -7
If you're wondering about a baffle because the exhaust is still pretty quite, as far as I know that one does not have a baffle. (I have that exhaust) the cat is where all the noise reduction happens so the bike won't get any louder unless you get the link pipe (which I also have). If you do the link pipe you will hear a noticeable increase in volume. That slip on is just a straight pipe from the cat. I do have the link pipe as well. Thanks for letting me know Taking a closer look at your picture I can see you do have the link pipe. Haha are you looking for more sound or less sound? For me the volume with the link pipe is just about perfect but I'm not too sure what you are looking for.
Post by Deleted on Dec 9, 2018 9:52:39 GMT -7
I do have the link pipe as well. Thanks for letting me know Taking a closer look at your picture I can see you do have the link pipe. Haha are you looking for more sound or less sound? For me the volume with the link pipe is just about perfect but I'm not too sure what you are looking for. My bike is stored in my house so I haven’t heard the sound in person (only on vids). I was just hoping there was an option to remove the baffle as I probably would have if I could.
Post by Deleted on Dec 9, 2018 13:19:55 GMT -7
I don't believe the Akra comes with a baffle since it's supposed to be a slip-on, and the stock one is also straight-thru. But it's super easy to find out: just peak inside the can. If you can see everything inside without any reduction in diameter from the outlet pipe, there's no baffle. If you want more noise than that, there's something wrong with your hearing man . It's going to be stupid loud. Give it a try and then report back here. I bet you'll be asking how to ADD a baffle after that. Ha ha. Good luck.
harri183
Post by harri183 on Dec 12, 2018 12:44:30 GMT -7
Won’t come with baffles and once you have heard it you will be buying one, you can get a full end piece with baffle but you need to drill out the rivets or you can buy just the baffle on its own and run a drill through the inner skin. I like my bikes loud but it’s just a bit too obnoxious even for my likings
exuptoy
Post by exuptoy on Dec 12, 2018 15:04:17 GMT -7
Thats why I went with the Leo Vince baffled pipe for my Scorpion RP1-GP. The baffle I purchased from Scorpion though was a joke! £39 or about $50 for this! I shit you not! The engineer I spoke to reckons it reduces it by around 1.5 - 2 db. I reckon they're full of shit!
Post by Deleted on Dec 13, 2018 10:54:46 GMT -7
I’ve confirmed that the slip on gas no baffle. Crap seeing the Akro isn’t cheap. I believe the full race system can has a baffle and had I don’t better research before buying and installing, I would’ve just bought the full race. It is what it is. I hope it sounds good in the spring.
Post by Deleted on Dec 13, 2018 10:55:57 GMT -7
Thats why I went with the Leo Vince baffled pipe for my Scorpion RP1-GP. The baffle I purchased from Scorpion though was a joke! £39 or about $50 for this! I shit you not! The engineer I spoke to reckons it reduces it by around 1.5 - 2 db. I reckon they're full of shit! Reduces? That’s like asking a girl to get a boob reduction. Im looking for my Braap potential if need be.
Post by thefinn on Dec 17, 2018 2:45:11 GMT -7
Ive installed my new Akrapovic link pipe and slip on and I was wondering whether anyone knows whether there is a removal BD KIller / Baffle in the can and how to remove it? Thanks so much for your help If you're wondering about a baffle because the exhaust is still pretty quite, as far as I know that one does not have a baffle. (I have that exhaust) the cat is where all the noise reduction happens so the bike won't get any louder unless you get the link pipe (which I also have). If you do the link pipe you will hear a noticeable increase in volume. That slip on is just a straight pipe from the cat. Did you test the slipon before the decat? The volume of the stock bike is quite enough for me, would just like a "gruntier" sound. Does the Akra can make an noticeable difference by itself?
panzer716
Post by panzer716 on Dec 17, 2018 8:57:25 GMT -7
If you're wondering about a baffle because the exhaust is still pretty quite, as far as I know that one does not have a baffle. (I have that exhaust) the cat is where all the noise reduction happens so the bike won't get any louder unless you get the link pipe (which I also have). If you do the link pipe you will hear a noticeable increase in volume. That slip on is just a straight pipe from the cat. Did you test the slipon before the decat? The volume of the stock bike is quite enough for me, would just like a "gruntier" sound. Does the Akra can make an noticeable difference by itself? Yes. I ran the slip on for about 1000 or so miles before the link pipe. If you are just looking for a slightly deeper sound with little to no volume increase, the slip on is perfect for that.
Post by Deleted on Dec 20, 2018 13:16:24 GMT -7
If you're wondering about a baffle because the exhaust is still pretty quite, as far as I know that one does not have a baffle. (I have that exhaust) the cat is where all the noise reduction happens so the bike won't get any louder unless you get the link pipe (which I also have). If you do the link pipe you will hear a noticeable increase in volume. That slip on is just a straight pipe from the cat. Did you test the slipon before the decat? The volume of the stock bike is quite enough for me, would just like a "gruntier" sound. Does the Akra can make an noticeable difference by itself? Good question, but no, I installed it all together
