mikefisher
Post by mikefisher on Nov 3, 2018 12:41:03 GMT -7
wired in a connector for a battery tender and now the abs is buzzing and there is no power to anything. Any ideas? only 4,000 miles on this new bike.
Post by Deleted on Nov 3, 2018 12:49:56 GMT -7
My guess is you inadvertently shorted the main fuse. Did you hear a zapping noise during your installation, by any chance? That'd be it. If not, check the main fuse anyway, since it has to be that. Good luck, and report back to us if all fuses look fine. I almost shorted mine when installing my pigtail; have to be really careful with those small batteries, since even a small wrench can reach the other end, and BAM! Hope this helps.
