mtate
1 Wheel Sex Appeal
Post by mtate on Oct 31, 2018 4:46:11 GMT -7
Looking into adjusting my suspension. Never done this before on a bike so it'll be an experience that I definitely don't want to mess up. Anyways I've been looking into some people's suggested setup and I came across Dave Moss track setup. Has anyone tried this? Is it going to be comfortable for street? or maybe you other guys can lead me in the right direction. Really just trying to soften it up a little bit.
Post by Deleted on Oct 31, 2018 11:56:50 GMT -7
It has to be a trial-and-error affair, unfortunately. It all depends on your weight, setup you want, etc. For me, I want the bike enjoyable in the twisties, which means less comfort on broken pavement, but I like a firm suspension. It was too firm stock, so I basically went 2 clicks/turns softer on everything except rear preload (which is a PITA to adjust on this bike, but feels softer than the front, so no adjustment needed IMO), Fortunately, that did the trick, apparently... but haven't had a chance to take the bike to any twisties yet. But the way it feels on the street leads me to believe it'll be perfect, since it feels pretty much like previous bikes that were fine when pushed. I'm around 160 (165 now, but will get down to 160) in the mornings with just shorts and T-shirt, as a reference. You can start like that, and go from there, since you seem to have the same complaint I did. Oh, but start bottoming out all settings first, to make sure you know where they were. Mine all were where the manual said, but bought my bike with 0 miles, so expected that. In addition, I marked the bottomed out positions with a dot (fine point permanent marker) on both parts, to know exactly where a full turn is. Then readjusted the settings with 2 clicks/turns (in case of front preload) less (as in softer) than factory. Good luck. JC
mtate
1 Wheel Sex Appeal
Post by mtate on Oct 31, 2018 13:19:16 GMT -7
It has to be a trial-and-error affair, unfortunately. It all depends on your weight, setup you want, etc. For me, I want the bike enjoyable in the twisties, which means less comfort on broken pavement, but I like a firm suspension. It was too firm stock, so I basically went 2 clicks/turns softer on everything except rear preload (which is a PITA to adjust on this bike, but feels softer than the front, so no adjustment needed IMO), Fortunately, that did the trick, apparently... but haven't had a chance to take the bike to any twisties yet. But the way it feels on the street leads me to believe it'll be perfect, since it feels pretty much like previous bikes that were fine when pushed. I'm around 160 (165 now, but will get down to 160) in the mornings with just shorts and T-shirt, as a reference. You can start like that, and go from there, since you seem to have the same complaint I did. Oh, but start bottoming out all settings first, to make sure you know where they were. Mine all were where the manual said, but bought my bike with 0 miles, so expected that. In addition, I marked the bottomed out positions with a dot (fine point permanent marker) on both parts, to know exactly where a full turn is. Then readjusted the settings with 2 clicks/turns (in case of front preload) less (as in softer) than factory. Good luck. JC Basically described me, I'm 160 and looking to just soften my setup a little bit cause like you said the stock suspension is just way to firm.
Post by Deleted on Oct 31, 2018 13:25:32 GMT -7
Sounds like what I did should be also perfect for you. And if not, pretty darn close. Those are my new 'base' settings. After that, I'd only do 1 change at a time, if needed. And finish off the adjustments that way. Let me know how it went, and what else you adjusted after that, if anything. Please post how you feel the bike in the twisties after the 'base' adjustment (before other adjustments), just to know what I might find myself too . Good luck brother.
Post by RedAndBlack on Oct 31, 2018 14:08:41 GMT -7
This is one of the things I recommend going to a professional for. For $40, my suspension tuner will set up your ride specific to the bike, riding style, and your height and weight. My suspension tuner will also allow you to come back for a reasonable amount of time to do adjustments for free.
It is, in my opinion, the best bang for your buck. Meaning that for a measly $40, you get a drastic change to the way your bike rides. There's not many modifications out there, especially in that price range, that have such a drastic change.
peripateticmike
Post by peripateticmike on Oct 31, 2018 14:14:52 GMT -7
This is one of the things I recommend going to a professional for. For $40, my suspension tuner will set up your ride specific to the bike, riding style, and your height and weight. My suspension tuner will also allow you to come back for a reasonable amount of time to do adjustments for free. It is, in my opinion, the best bang for your buck. Meaning that for a measly $40, you get a drastic change to the way your bike rides. There's not many modifications out there, especially in that price range, that have such a drastic change. Agree, I'm at 225lbs and after taking it to my suspension tuner (he does all my bikes) it was night and day, it's the best $50 you can spend. However, I'm more performance focused and at my weight the suspension is now pretty stiff as a result and after setting rear sag. Where are you located?
Post by papawheelie on Oct 31, 2018 14:16:52 GMT -7
How does one go about finding a professional suspension tuner, if one doesn't have those sort of contacts? I can’t even find a bike shop that I trust to touch my stuff. I do all my own work, for that reason.
Maybe OP is in that same boat?
Post by RedAndBlack on Oct 31, 2018 14:23:16 GMT -7
How does one go about finding a professional suspension tuner, if one doesn't have those sort of contacts? I can’t even find a bike shop that I trust to touch my stuff. I do all my own work, for that reason. Maybe OP is in that same boat?
I think most have companies, at least in my area. I mean I live in SD so I have the option of like maybe half a dozen within a reasonable drive so it is probably more of a normal thing out here then maybe someplace in East Bumble Idaho. But They all have companies advertising these services and would come up in google/yelp/facebook etc.
EDIT: On that last note, if you're on facebook, I'm sure most areas have area specific sportbike rider groups. Post up in there asking for recommendations for suspension tuner.
The second option would be to check out your local track organizations and see who comes out to their trackdays to do suspension tuner for riders. Almost every trackday I've ever went to had a suspension tuner onsite.
Finally, find a mechanic that works on a raceteam. Whether it be MotoAmerica or something semi professional. A lot of these guys are mechanics and have their own shops they operate during the offseason. Most of these guys will be very proficient in setup of a motorcycle suspension.
peripateticmike
Post by peripateticmike on Oct 31, 2018 14:29:18 GMT -7
San Diego?
Post by RedAndBlack on Oct 31, 2018 14:57:29 GMT -7
Yessir!
peripateticmike
Post by peripateticmike on Oct 31, 2018 16:09:41 GMT -7
Me too! So you probably know or know of Dax then?
Post by Deleted on Oct 31, 2018 18:38:17 GMT -7
Meaning that for a measly $40, you get a drastic change to the way your bike rides. Well, for me it'd be a hell of a lot more than that, by the time you factor in travel expenses . And being very close to the ideal weight the factory uses to set up the suspension, I wouldn't even pay those 'measly' $40 unless I really needed to (I don't). I like working on my bikes, and setting up suspension for the street is not rocket science. It just takes trial and error, and same thing even for a professional. But to each his own. In my case, I have no choice but to do it mysel. And fortunately, I like those challenges too. He he. And same thing with oil changes and other maintenance. I much rather do it myself even if they were free .
mtate
1 Wheel Sex Appeal
Post by mtate on Nov 1, 2018 5:57:26 GMT -7
This is one of the things I recommend going to a professional for. For $40, my suspension tuner will set up your ride specific to the bike, riding style, and your height and weight. My suspension tuner will also allow you to come back for a reasonable amount of time to do adjustments for free. It is, in my opinion, the best bang for your buck. Meaning that for a measly $40, you get a drastic change to the way your bike rides. There's not many modifications out there, especially in that price range, that have such a drastic change. I wish I knew of a suspension tuner around here, guess I'll have to start looking. Wish I had access to yours lmao, I'd dish out $40 in a heartbeat to have someone set me up.
mtate
1 Wheel Sex Appeal
Post by mtate on Nov 1, 2018 5:59:10 GMT -7
This is one of the things I recommend going to a professional for. For $40, my suspension tuner will set up your ride specific to the bike, riding style, and your height and weight. My suspension tuner will also allow you to come back for a reasonable amount of time to do adjustments for free. It is, in my opinion, the best bang for your buck. Meaning that for a measly $40, you get a drastic change to the way your bike rides. There's not many modifications out there, especially in that price range, that have such a drastic change. Agree, I'm at 225lbs and after taking it to my suspension tuner (he does all my bikes) it was night and day, it's the best $50 you can spend. However, I'm more performance focused and at my weight the suspension is now pretty stiff as a result and after setting rear sag. Where are you located? I'm in North Carolina. I'm gonna take my bike to get its first service knocked out today and I'm going to talk to the guy there and see if he does suspension tuning.
Post by thefinn on Dec 13, 2018 17:30:49 GMT -7
Looking into adjusting my suspension. Never done this before on a bike so it'll be an experience that I definitely don't want to mess up. Anyways I've been looking into some people's suggested setup and I came across Dave Moss track setup. Has anyone tried this? Is it going to be comfortable for street? or maybe you other guys can lead me in the right direction. Really just trying to soften it up a little bit. Start off with this video. He explains it in a very simple way. You are on the right track with Dave Moss imo, you just need to get the basics nailed down first. Important things is to set rider sag (preload) and rebound. Once they are set, you barely have to touch them more than once a year. Maybe adjust them one click for the harder after setting up if you still feel a little "pogo" The compression is what you will play with to change between sporty riding or gliding down the highway. With Dave Moss and other internet pages or videos, you will pretty quickly get the bike at a weekend warrior level yourself. If you are only looking for results and not learning something, absolutley spend those $40 for someone to do it for you and get it over with. Once you get into the world of suspension yourself, itll be a lot more expensive than $40. Edit: By expensive I mean in suspension mods, not damage to the bike.
exuptoy
Post by exuptoy on Dec 24, 2018 6:43:18 GMT -7
I watched the Dave Moss suspension set up video for the FZ/MT and track setup IMO would be too hard for the street, but the track setup video ran straight into the street setup video with a guy at one of Dave's street sessions.
On this site somewhere I've read that someone here dropped the front end 20mm and I was thinking man thats excessive and it'll cause issues due to instability but in Dave's video he made a comment that on his findings on his very own MT10 following 8000 miles in 6 months, he found the best setting for the front height was to drop the forks through the yokes from the first ring to the 3rd which is indeed a 20mm drop! Added to this the fact he backed off the rebound and compression at the front and raised the rear end by increasing the rear preload. It would have been nice to find a testimonial from the guy confirming the settings made a difference (big or small) but hey ho, it is what it is.
Co-incidentally on Dave's site, my testimonial is on the first page from when he gave me advice on my old RR9 Blade and the difference to that was night and day (although the settings he offered me did end up too much for street work and I softened them upon a little over the following month and it was nigh on perfect, for me at least).
theculturalattache
Post by theculturalattache on Dec 25, 2018 9:47:35 GMT -7
Yep,
some idiot on here dropped the yokes 20mm.
it was me!
Got the idea from the dave moss video.
Did it work?
Absolutely,bike turns in much better now.
High speed stabiliy didn't seem affected.
The strange thing is that on the R1 forums they say you should raise the front!
Bearing in mind that it is the same chassis...
Anyway,I recommend you do it, and try it.
It worked for me, if it doesn't work for you put it back to stock.
Doesn't cost a penny.
I'am in the process of changing out shock at the moment but unfortunately am recovering from an operation so won't be able to ride for another six to eight weeks.
Merry Christmas everyone.
exuptoy
Post by exuptoy on Dec 25, 2018 12:02:38 GMT -7
I would never call anyone an idiot but it sort of does fly in the face of accepted practice to go that far but hey, if DM recommends it then the guy knows his stuff. I'm glad it worked for you though and once I have a few more miles on mine it'll be getting the suspenders adjusted. Mine is only showing 700 miles just now so I want it at least with 1000 miles on the clock so it will be loosened up.
theculturalattache
Post by theculturalattache on Dec 26, 2018 11:35:04 GMT -7
When I said "some idiot on here..."I was referring to myself because the dark art of suspension tuning is one I certainly don't fully understand.
Also,whether its changing a wheel, brakes,battery or whatever it always seems to take me a day, everyone else an hour.
Hence"some idiot..."
Wasn't implying at all you called me an idiot.
Type into a search engine something like "english humour",might help to explain.
Merry Christmas!
exuptoy
Post by exuptoy on Dec 26, 2018 12:29:13 GMT -7
Type into a search engine something like "english humour",might help to explain. Merry Christmas! It's ok matey, I'm from South Wales in the UK. I know it well.
