jroc
Post by jroc on Oct 19, 2018 0:04:51 GMT -7
I installed Flash Tune on my 2018 tonight. I first installed the bikeside harness, then successfully flashed the ECU. I test started the bike and it started and ran as normal. I already had a M4 3/4 exhaust installed.
Next, I removed the AIS and installed blockoff plates. I also removed the stock O2 sensors, and installed the the FTECU Active Tune O2 sensor with lambda controller. I then reflashed to activate the Active Tune with live tuning enabled.
The bike would start, idle under 1k, bog and stall. Throttle application does nothing. I've tried flashing with the stock flash, unlocked flash, Graves flash, and a flash I received from Stoltec. They all have the same result.
Any ideas? I have a trackday on Saturday and really want to get this sorted out
jroc
Post by jroc on Oct 19, 2018 7:08:54 GMT -7
I woke up this morning and flashed the same exact image to the bike..... All of a sudden it works as it should. Active Tune provides readings and corrections, and bike starts and idles and revs as it should. Not sure what to make of it
