mtate
1 Wheel Sex Appeal
Post by mtate on Oct 14, 2018 18:01:40 GMT -7
So I found out why my Quickshifter was not working after installing some ASV levers. There’s a little button that the top of the lever covers, on the OEM lever there is a tab that pushes the button in so cruise control and the Quickshifter will work. When the button is not compressed neither will work. Would there be any problem if I just found a way to keep that button compressed 24/7?
revolvingrain
Post by revolvingrain on Oct 14, 2018 18:09:40 GMT -7
i just ran into the same problem today; new lever and cruisecontrol and quickshifter wouldnt activate. I've read alot of people on this forum say the same thing about the ASV levers; sometimes it was bad installation but alot of it was just defective levers and so they had them replaced. As for your idea to keep the button pushed, not a good idea because then your cruise control wouldnt turn off when you would pull in the clutch; at least thats my train of thought.
mtate
1 Wheel Sex Appeal
Post by mtate on Oct 14, 2018 18:27:05 GMT -7
i just ran into the same problem today; new lever and cruisecontrol and quickshifter wouldnt activate. I've read alot of people on this forum say the same thing about the ASV levers; sometimes it was bad installation but alot of it was just defective levers and so they had them replaced. As for your idea to keep the button pushed, not a good idea because then your cruise control wouldnt turn off when you would pull in the clutch; at least thats my train of thought. If cruise works like any other car just a quick tap of the break will shut it down also. One thing I thought might be a problem is the fact the Quickshifter will always be engaged and could possibly be bad if you’re downshifting? I’ll try and get ahold of the people I got it from and see if I got the wrong lever or if they have a solution though.
mtate
1 Wheel Sex Appeal
Post by mtate on Oct 14, 2018 18:43:31 GMT -7
I actually just saw the other thread. Ima look in the cases the levers came in when I get a chance to see if there’s a tab I can add to it.
