zenmoto
Post by zenmoto on Aug 7, 2018 13:47:33 GMT -7
I have a feeling I'm all alone on this one, but my speedometer has been cutting out recently (the last 4 rides). It will work fine for quite a while then, with no real reason, it will just suddenly read zero.
I've noticed my ABS light coming on / off a time or two just prior the speedo dropping to zero. Once it goes to zero the check engine, TCS, and ABS lights all come on. ...otherwise the bike runs fine (no cruise control, obviously), but the FTECU quick shifter and auto blip still work, the tachometer is still reading revs accurately, etc. ...just no speedo.
If I switch the bike off and back on, it resets and works, though it is prone to cutting out again after a short while.
I'm sure I'll have to go in and check all the connectors, ABS sensor, etc. ...just thought I'd ask and see if anyone has seen something similar. ...I need to dig in to it, but man ...it's been too damn hot in the garage!!! lol
Post by RedAndBlack on Aug 7, 2018 13:54:55 GMT -7
Sounds like a wheel sensor issue. All of those lights come on when there's a wheel sensor issue. Check the wheel sensors and make sure they are aligned properly and have the proper gap between the sensor rings on the wheels. Otherwise, one of them might be faulty and failing.
zenmoto
Post by zenmoto on Aug 7, 2018 15:13:08 GMT -7
Thanks, that gives me a good place to start. ...much appreciated.
