loading
Post by loading on Jul 2, 2018 19:24:01 GMT -7
Hey all, Looking for some advice. I recently installed a Graves 3/4 Cat Eliminator Exhaust and AIS block off plates. I purchased a FTECU bench flashing kit in order to remove the O2 sensors, EXUP valve, and AIS. I'm still using the stock air filter and I don't have Active Tune or a Power Commander. I flashed the bike with the following file in FTECU file manager: 17 FZ10-B67-8591A-10(US)-Graves Cat Elim sound insert removed 101216.ftm I have no check engine lights on and everything seems to be working fine except that my cruise control does not work . I've checked all of the switches including my clutch, front brake, rear brake, and side stand and they're all working correctly. I'm not using a servo buddy nor did Graves supply any kind of "blank" plug to put into the AIS plug (I just wrapped it in electrical tape to protect it). Any ideas other than sending this to Nels? Thanks, Loading P.S. One other oddity. I purchased a 6-pin to OBD2 cable to try to read the codes but Torque Pro can't find the correct protocol to talk with my bike. I never tried it with the stock flash so I'm not sure if this ever worked but wondering if anyone else is unable to read their codes with an OBD2 reader after doing the Graves flash.
loading
Post by loading on Jul 3, 2018 8:12:08 GMT -7
So I fixed my problem. Turns out there is a setting in the FTECU software that confused me. "Disable Cruise Lockout" should be set to TRUE. Then cruise will work. Cheers! On the Road Claude McKay
panzer716
Post by panzer716 on Jul 5, 2018 14:49:42 GMT -7
So I fixed my problem. Turns out there is a setting in the FTECU software that confused me. "Disable Cruise Lockout" should be set to TRUE. Then cruise will work. Cheers! On the Road Claude McKayGlad we could help.
thejackgraves13
Post by thejackgraves13 on May 12, 2020 5:36:43 GMT -7
Did this Graves file shut off the O2s already. I was thinking of using the same Flash. Thank you
h19hsp33d
Post by h19hsp33d on Jul 19, 2020 1:39:55 GMT -7
Did this Graves file shut off the O2s already. I was thinking of using the same Flash. Thank you Depends on what you mean by "already"? ... should be able to switch on/off manually after any re-flash.
loading
Post by loading on Aug 7, 2020 8:47:03 GMT -7
Sorry, haven't checked this thread in a long time. Yes, the grave file shut off the 02s.
motoxr392
Post by motoxr392 on Oct 3, 2021 8:10:08 GMT -7
What ECU part number do you have? I have the -51 ECU and wondering if the -10 Graves file is safe to run?
