tonyko818
Post by tonyko818 on May 23, 2018 18:17:41 GMT -7
1st gen fz1/ had a low speed drop on the right side. engine stalled, took a few minutes to get it started but seemed ok. rode a couple miles and overheated, apparently there is no oil pressure. I loosened the gallery bolt and nothing came out. What could have happened? Also replaced the oil and filter recently but drove it on a 250 mile trip with no issues before this incident. Any thoughts appreciated. Thanks
Post by evitzee on May 23, 2018 20:25:39 GMT -7
It seems you are in the wrong forum if you are riding a 1st Gen FZ1. This forum is for the FZ-10 machine which has a completely different engine than your bike.
But in response to your question the oil light on your machine is an oil level light and NOT a pressure light. If you opened the drain bolt and nothing came out you certainly have a major issue, but it is hard to believe you lost 3 or 4 quarts of oil over the past few hundred miles and not noticed it, either with a mess all over the bike or a huge puddle under the bike when parked.
Good luck.
