tashko
Post by tashko on May 4, 2018 18:13:42 GMT -7
Hi Everyone im from switzerland im 25 and i buy the mt10 2016 model just a week ago im new to motorcyle and i dont speak or write good english so take it easy whit me. I open this thread bec i need awnswers to my stupid mistake i left my mt10 in P position and it drain the battery i went and buy charger recharge the battery and put it in only to connect the wires WRONG ( YEA BIG IDIOT MY WIFE TELLS THAT TO ME ALMOST EVERY DAY) so when i did that i blow up the main RED FUSE litle bit smoke from the battery and that's it i went buy new battery and fuse i connect it RIGHT that time and i try to start the bike it light up the board the lightst everything but when i press the start button it cranks and litle bit smoke from the exhaust and that's it.
kingcrimson
Post by kingcrimson on May 4, 2018 22:26:56 GMT -7
Take it to a qualified sportbike mechanic and quit fidgeting with the MT-10 before you blow up the engine.
BTW - your wife is very smart.
kcking1177
Post by kcking1177 on Feb 23, 2020 12:43:32 GMT -7
Did you ever figure out what you needed to do to fix it I never switched my battery but seems to be doing the exact same thing yours is
Post by RedAndBlack on Feb 24, 2020 14:44:10 GMT -7
Just a heads up, op hasn't returned to the forum since the day he posted this almost 2 years ago. Hope you get it sorted!
kohtachi
Post by kohtachi on Feb 24, 2020 17:48:51 GMT -7
that was silly, but it happens! i hope he come back and tells us if it has been resolved.
jaygilbert9
Post by jaygilbert9 on Jan 11, 2021 10:29:35 GMT -7
Hi, can any one tell me the answer to this as i have managed to do exactly the same as the original post and now mine wont start either!
this is my first time posting as i have only recently got an MT10.
any help would be appreciated
Post by willl84 on Jan 11, 2021 10:33:37 GMT -7
If you hooked up the charger backwards to the battery you may have popped the main fuse. That's what I'd be checking first
fjrchuck
Post by fjrchuck on Jan 11, 2021 12:15:05 GMT -7
Been there and done that.......new main fuse fixed it! If you hooked up the charger backwards to the battery you may have popped the main fuse. That's what I'd be checking first
jaygilbert9
Post by jaygilbert9 on Jan 12, 2021 2:49:11 GMT -7
thanks for your replies, i had blown the main fuse id already replaced this by the time i posted the message above.
bike was turning over and all the clocks coming to life after replacing the main fuse but still wouldn't fire!
after a rough nights sleep came back to it and spotted the ETV (electric throttle valve) 7.5 fuse had also blown.
put the "spare" one in out the middle fuse box and it fired!!!
man im so happy my bikes not broke.... sort of.
ill replace the spare fuse today but seems i might have an oil leak and my coolant is empty!!
going to top up the coolant today then keep an eye on it over the next day or so and see.
any more advice would be great thankyou!
Post by willl84 on Jan 12, 2021 6:00:56 GMT -7
thanks for your replies, i had blown the main fuse id already replaced this by the time i posted the message above. bike was turning over and all the clocks coming to life after replacing the main fuse but still wouldn't fire! after a rough nights sleep came back to it and spotted the ETV (electric throttle valve) 7.5 fuse had also blown. put the "spare" one in out the middle fuse box and it fired!!! man im so happy my bikes not broke.... sort of. ill replace the spare fuse today but seems i might have an oil leak and my coolant is empty!! going to top up the coolant today then keep an eye on it over the next day or so and see. any more advice would be great thankyou! Glad it was something simple! Always check all the fuses first!
trivkywoo
Post by trivkywoo on Jan 12, 2021 7:40:17 GMT -7
25, new to biking, surrounded by hairpin bends half way to Olympus and buys an MT-10?
Maybe the Swiss aren't so risk averse after all!
