roosterxp
Post by roosterxp on Feb 13, 2018 16:09:27 GMT -7
Hey gang, I got a 2wdw ecu reflash and I bought the graves block off plates. Ecu has been calibrated for the block offs.. my question:. I have a full tank of gas, I really have no way to drain the tank so I can install the plates.. I thought I read somewhere that there is a Jose you can kink off and it does the same thing.. I just need to do this till my first tank is empty then I'll tear it all dwon and install the plates. Any ideas?
Post by achrista on Feb 13, 2018 16:29:14 GMT -7
You dont need to drain the tank to pull it off. It will be a bit heavier when it's full of fuel, so dont drop it. I dont know the mechanical term, but there is a valve on the tank/line that prevents gas from spilling. If you're concerned with weight, you can just siphon the gas out using a marina-style pump. I had a buddy with a Benz who had to pump all his oil out every change (lol).
Richies bikes on YouTube did a very comprehensive walkthrough of ais removal:
guywithfz10
Post by guywithfz10 on Feb 13, 2018 17:58:35 GMT -7
No need to drain the tank. It wont spill when you unlatch the fuel line. Just dont flip the tank upside down or drop it 😁
roosterxp
Post by roosterxp on Feb 13, 2018 19:46:21 GMT -7
Sweet! This will go way easier now! Thanks guys
roosterxp
Post by roosterxp on Feb 14, 2018 14:13:05 GMT -7
Well boys, I got it all done. Unhooking the fuel line on the tank I maybe lost 2 drips.. literally! The outside Allen head on the smog plates were a bugger, they we're tight all the way to the end of the threads. I think what took the longest was trying to get that plastic rivit back in he bottom hole on the clutch side for the intake panel. I must have fought with that thing for 20 min! I started her up and she is loud. I also installed a dan-moto delete pipe. I am also using a yoshimura FZ-10 muffler. It's a shorty muffler.. just the few revs know the stand and it really barks! There is just too much snow up here in mn to ride.. although it reached 40 degrees! Heat wave!
Post by clayton on Feb 14, 2018 19:15:13 GMT -7
Well boys, I got it all done. Unhooking the fuel line on the tank I maybe lost 2 drips.. literally! The outside Allen head on the smog plates were a bugger, they we're tight all the way to the end of the threads. I think what took the longest was trying to get that plastic rivit back in he bottom hole on the clutch side for the intake panel. I must have fought with that thing for 20 min! I started her up and she is loud. I also installed a dan-moto delete pipe. I am also using a yoshimura FZ-10 muffler. It's a shorty muffler.. just the few revs know the stand and it really barks! There is just too much snow up here in mn to ride.. although it reached 40 degrees! Heat wave! We need pics and a sound vid!!!
roosterxp
Post by roosterxp on Feb 24, 2018 15:46:59 GMT -7
roosterxp
Post by roosterxp on Feb 24, 2018 15:57:21 GMT -7
Ive got a 29 sec vid of the exhaust as well, how do i upload that?
ghostrider1127
Post by ghostrider1127 on Feb 24, 2018 16:02:47 GMT -7
reflash , switch off the AIS , all can be left in place . that´s all...
roosterxp
Post by roosterxp on Feb 24, 2018 18:26:25 GMT -7
reflash , switch off the AIS , all can be left in place . that´s all... Way ahead of you bro! I had my ECU flashed by 2wdw. All done at the same time. I want to know how to post the video iade of the exhaust..
Post by Cruizin on Feb 24, 2018 21:54:14 GMT -7
reflash , switch off the AIS , all can be left in place . that´s all... Way ahead of you bro! I had my ECU flashed by 2wdw. All done at the same time. I want to know how to post the video iade of the exhaust.. Upload the video to youtube and then paste the "share" link into a post.
cr121
Post by cr121 on Feb 24, 2018 23:10:47 GMT -7
When I spoke with 2 Wheel Dynoworks they said that even though the flash would disable the AIS they still recommended installing the block off plates. So I spent my Saturday taking my bike apart, and installing the block off plates, and my new exhaust. Now, I just have to wait for my ECU to come back.
Temps are rising here in TN, and the wait is killing me. I know it will be all worth it when I finally get this all done. Back roads here I come!!
ghostrider1127
Post by ghostrider1127 on Feb 25, 2018 2:42:56 GMT -7
reflash , switch off the AIS , all can be left in place . that´s all... Way ahead of you bro! I had my ECU flashed by 2wdw. All done at the same time. I want to know how to post the video iade of the exhaust.. Highly doubt about that BTW was just answer to you .
