Post by Deleted on Dec 28, 2019 18:19:19 GMT -7
Vehicle manufacturers don't always put and/or recommend what's best for the vehicles they make. An easy example is the HUGE tires (up to 240s) some install on some cruisers; just because they're bigger, doesn't mean they are better. They turn worth a crap; they're just for looks. At the other side of the spectrum, a 160 tire wouldn't make sense in our bikes either. There's an optimal size somewhere in the middle, that engineers would always push for, but there're other forces at play, from marketing folks, EPA, lawyers, and bean counters. Many times is up to owners to figure out what's best your his/her motorcycle, from tire size, brakes, suspension, etc. Manufacturers rarely put the best components right off the bat. And anybody smart enough knows that . So nothing wrong questioning their choices, and trying to improve your ride .
gunnar
fabbin stuff...
Post by gunnar on Dec 29, 2019 11:50:40 GMT -7
Vehicle manufacturers don't always put and/or recommend what's best for the vehicles they make. An easy example is the HUGE tires (up to 240s) some install on some cruisers; just because they're bigger, doesn't mean they are better. They turn worth a crap; they're just for looks. At the other side of the spectrum, a 160 tire wouldn't make sense in our bikes either. There's an optimal size somewhere in the middle, that engineers would always push for, but there're other forces at play, from marketing folks, EPA, lawyers, and bean counters. Many times is up to owners to figure out what's best your his/her motorcycle, from tire size, brakes, suspension, etc. Manufacturers rarely put the best components right off the bat. And anybody smart enough knows that . So nothing wrong questioning their choices, and trying to improve your ride . This coming from a guy who puts aftermarket parts on his bike, then complains about being "not OEM enough looking" (unless only he installs the parts, then it's fine) thinking 10-12 ounces of weight saving removing a half inch of aluminum and 10mm of rubber is magically going to make his bike perfect. I'm sure a racer or test rider can easily feel the differences and make recommendations, (but not you, you're not smart enough) and I'm sure I couldn't tell any difference. As for the 240 rear, I have a bike with one of those, and surprisingly it will turn/change directions as quick as I can on my MT10, but with 25 degrees less lean angle, there are limits, (but you're right it does look good).
Post by clayton on Dec 29, 2019 15:15:42 GMT -7
Vehicle manufacturers don't always put and/or recommend what's best for the vehicles they make. An easy example is the HUGE tires (up to 240s) some install on some cruisers; just because they're bigger, doesn't mean they are better. They turn worth a crap; they're just for looks. At the other side of the spectrum, a 160 tire wouldn't make sense in our bikes either. There's an optimal size somewhere in the middle, that engineers would always push for, but there're other forces at play, from marketing folks, EPA, lawyers, and bean counters. Many times is up to owners to figure out what's best your his/her motorcycle, from tire size, brakes, suspension, etc. Manufacturers rarely put the best components right off the bat. And anybody smart enough knows that . So nothing wrong questioning their choices, and trying to improve your ride . This coming from a guy who puts aftermarket parts on his bike, then complains about being "not OEM enough looking" (unless only he installs the parts, then it's fine) thinking 10-12 ounces of weight saving removing a half inch of aluminum and 10mm of rubber is magically going to make his bike perfect. I'm sure a racer or test rider can easily feel the differences and make recommendations, (but not you, you're not smart enough) and I'm sure I couldn't tell any difference. As for the 240 rear, I have a bike with one of those, and surprisingly it will turn/change directions as quick as I can on my MT10, but with 25 degrees less lean angle, there are limits, (but you're right it does look good). I agree My Yamaha Raider come from the factory with a 210 rear and I switched to a 240 and man does that bike handle awesome in the curves. Majority of Raider owners first mod is switching out that crappy factory metzler 210 for the cobra Avon 240. Much longer thread life and handles freakin awesome. Iv got over 31,500 miles on my Raider now and on my 3rd 240.
nicklabrie
Post by nicklabrie on Feb 23, 2020 18:51:52 GMT -7
... Also, liability wise, a company would not release a product that will only work with one tire. What?
blackclu
Post by blackclu on Feb 23, 2020 18:58:05 GMT -7
... Also, liability wise, a company would not release a product that will only work with one tire. What? Because if they did, shops would put other tires on, people would crash and they would sue yamaha. I have raced 200/60 tires. It works wonderfully.
