mmunoz
Post by mmunoz on Jan 20, 2018 20:22:36 GMT -7
Hi All, Wanted to let everyone know Ohlins Steering Damper for the YZF R1 (2015 and beyond) also fits the FZ 10 / MT 10. Ohlins SD 047 is the specific part number. Ohlins for some reason will not acknowledge that it fits the FZ 10 / MT 10. In fact, they will tell you it doesn't fit. Picked it up from my local dealer today and installed with no issues. Stock steering damper wasn't strong enough and I would get too much head shake. The FZ 10's front end can get light in a hurry as you all know, so I felt this was a needed upgrade. Stock electronic steering damper looks like it runs into the front cowling (headlight housing), but it actually runs back and into the fake air scoop on the right side of the bike. Easy to get to once you know the location.
Post by Cruizin on Jan 20, 2018 20:43:43 GMT -7
Hi All, Wanted to let everyone know Ohlins Steering Damper for the YZF R1 (2015 and beyond) also fits the FZ 10 / MT 10. Ohlins SD 047 is the specific part number. Ohlins for some reason will not acknowledge that it fits the FZ 10 / MT 10. In fact, they will tell you it doesn't fit. Picked it up from my local dealer today and installed with no issues. Stock steering damper wasn't strong enough and I would get too much head shake. The FZ 10's front end can get light in a hurry as you all know, so I felt this was a needed upgrade. Stock electronic steering damper looks like it runs into the front cowling (headlight housing), but it actually runs back and into the fake air scoop on the right side of the bike. Easy to get to once you know the location. Thanks for sharing that!
ek5425
Post by ek5425 on Jan 20, 2018 23:10:09 GMT -7
Did the little steering damper warning light next to the neutral light come on?
ghostrider1127
Post by ghostrider1127 on Jan 21, 2018 4:48:28 GMT -7
Connector with eliminator it´s included
mmunoz
Post by mmunoz on Jan 21, 2018 9:28:14 GMT -7
Yeah, kit for the Yamaha R1 / FZ 10 / MT 10 comes with a resistor which plugs in where you unplug the old electronic steering damper.
kdawg
Post by kdawg on Jul 21, 2020 23:02:40 GMT -7
Did you have to remove the air scoop fairing? Also you used the eliminator that came with the ohlins damper? Torque settings? Lmk I want to do this upgrade. Thanks in advance.
Post by rracerfz10 on Aug 12, 2020 17:19:12 GMT -7
What does one of these cost?
