warnock
Post by warnock on Aug 26, 2016 5:03:20 GMT -7
Does anyone know the size of the socket needed for the rear axle nut? I would like to tighten my chain but can't find the size anywhere.
coyote
Post by coyote on Aug 26, 2016 5:52:23 GMT -7
You need a 32mm socket.
warnock
Post by warnock on Aug 26, 2016 8:33:48 GMT -7
Thanks buddy! Appreciate the quick response.
dadbot
Post by dadbot on Apr 5, 2019 13:01:38 GMT -7
Hello! Can you confirm the 32mm worked?
redgecko59
Post by redgecko59 on Apr 5, 2019 16:24:07 GMT -7
Hello! Can you confirm the 32mm worked? Yes it's a 32mm
daveinwoodland
Post by daveinwoodland on Apr 6, 2019 9:21:29 GMT -7
32MM is it, I also have a torque wrench when I do it as it requires about 130lbs of torque when retightening.
twistydave
Post by twistydave on May 24, 2019 10:49:32 GMT -7
Thanks guys!! 32mm and 130lbs. awesome
jdmt10
Post by jdmt10 on Nov 20, 2022 18:48:29 GMT -7
Does anyone thing 140 ftlbs per the manual is a little too much for the rear axle I don't want to put unnecessary stress on the bearings
Post by mt10orc on Nov 20, 2022 22:20:28 GMT -7
So I have LightTech chain adjusters and torque at 90ft lbs per instructions. I really think that 130-140 lbs is a bit overboard, but that is the spec, in my experience I think in or around 100lbs is ok, but don’t want anyone to think that is gospel.
minlak
Post by minlak on Nov 21, 2022 5:54:30 GMT -7
So I have LightTech chain adjusters and torque at 90ft lbs per instructions. I really think that 130-140 lbs is a bit overboard, but that is the spec, in my experience I think in or around 100lbs is ok, but don’t want anyone to think that is gospel. Isn't Lighttech recommendation 100NM?? Was on my instructions
Post by mt10orc on Nov 21, 2022 13:03:25 GMT -7
So I have LightTech chain adjusters and torque at 90ft lbs per instructions. I really think that 130-140 lbs is a bit overboard, but that is the spec, in my experience I think in or around 100lbs is ok, but don’t want anyone to think that is gospel. Isn't Lighttech recommendation 100NM?? Was on my instructions Hell I can’t remember. I use 90lbs want to say it’s like 87lbs, but just rounded up if memory serves me. See edit below. Edit per LightTech:TOURQE YOUR REAR AXLE NUT TO THE LIGHTECH SPECIFICATIONS, (which calls for 100nm or 72ft-lbs). I’ve been wrenching on bikes and vehicles for most of my adult life, born in ‘67. 90-100lbs is a standard torque average for almost all wheels I’ve put on most of my life. It’s in my head and what I use. Feel free to do whatever you feel safe doing. I’ll just say that I’ve never had anything fall off. Maybe I’m just lucky. I know before I installed the LightTech’s I torqued the wheel nut to 130lbs. I have to say it was a bit overboard IMO. Probably best to stick to the required torque set by manufacturers. Believe LightTech states the lower torque because they were breaking at the manufacturer settings. Here is a standard chart for wheel torque.
semprenissart
Post by semprenissart on Nov 24, 2022 21:52:42 GMT -7
So I have LightTech chain adjusters and torque at 90ft lbs per instructions. I really think that 130-140 lbs is a bit overboard, but that is the spec, in my experience I think in or around 100lbs is ok, but don’t want anyone to think that is gospel. I also have Lightech adjusters and do the same thing. 90ft lbs which I think is enough also I read somewhere that someone torqued it to specs and that broke the Lightech adjusters doing so
