Post by clayton on Dec 9, 2017 7:14:14 GMT -7
Does anyone make a side mount license plate bracket that bolts to the swing arm axle bolt on the 10? That’s the way I mounted my plates on my raider and katana 600. Would like to do that to the mt10 when I get one next year.
Post by RedAndBlack on Dec 10, 2017 12:23:03 GMT -7
I don't know much about these plate mounts. Any mount that fits the Yamaha R1 that is designed to replace the "chain puller" block that goes on the axle that you use as your reference to adjust the chain should be interchangable with the FZ10. I don't think this part changed on the R1s in a few years so earlier years might be compatible, but anything 2015+ designed for the R1 should definitely fit the FZ10.
Good luck with your search. As always, post up what you find so users in the future who want to do the same can find your post via search.
