gsxwetodddid
Post by gsxwetodddid on Oct 27, 2017 4:17:27 GMT -7
I found out yesterday after 14,000 miles that i need to replace my clutch due to slipping while holding the clutch in at a traffic light. So...I am wondering if anyone has some recommendations on a clutch kit that can last a while. I have been told that EBC is a good brand and has a kit for the bike. Is this a good one or are there others......thoughts?
Post by Deleted on Oct 27, 2017 10:52:24 GMT -7
I found out yesterday after 14,000 miles that i need to replace my clutch due to slipping while holding the clutch in at a traffic light. Lets look into this further before you start buying parts! You say that at a light you've got the clutch in and its slipping. I'm taking this to mean that bike is stopped and in gear, clutch lever is pulled, and the bike continues to pull forward. If so, this is a clutch disengagement issue and not caused by a worn clutch. I would recommend you take a look at the clutch cable and lever. If the cable has a lot of slack the clutch will not fully disengage when the lever is pulled. If you have a lever that is adjusted too close to the bar the clutch will also not fully disengage (this is common with cheap aftermarket levers). And lastly, a little bit of pull in neutral is normal, especially when the oil and transmission are still cold. If you put a bike up on a stand and start it up, the rear wheel will spin even if its in neutral. Symptoms of a worn clutch include rising engine speed without corresponding increase in speed, especially under heavy throttle in high gear, and a clutch engagement point that is noticeably further out than it was before.
audiblepop94
Post by audiblepop94 on Oct 28, 2017 18:20:43 GMT -7
This ^^^^^
gsxwetodddid
Post by gsxwetodddid on Nov 7, 2017 12:32:49 GMT -7
Well i have had multiple experienced riders take a look at my bike and clutch, both said that the cable would need to be adjusted. I then brought the bike to my buddies shop and they adjusted the clutch, took a ride around the building and i was able to repeat the problem. rode it back around and had the shops owner take it and he was able to get it to roll on its own around the building. Also a secondary effect is that i am unable to shift into neutral while stopped, i have to be rolling slightly to pop into neutral.
The pull i am experiencing is rather considerable, its able to get up to a good speed if i keep it going.
Now that you mention it it does feel like the motor is at a higher rev for my normal speed of 65 on my commute to work.
this is my second bike and the first time ive had issues with the clutch so i do appreciate your input, and i am open to any other ideas.
audiblepop94
Post by audiblepop94 on Nov 7, 2017 13:04:45 GMT -7
Well i have had multiple experienced riders take a look at my bike and clutch, both said that the cable would need to be adjusted. I then brought the bike to my buddies shop and they adjusted the clutch, took a ride around the building and i was able to repeat the problem. rode it back around and had the shops owner take it and he was able to get it to roll on its own around the building. Also a secondary effect is that i am unable to shift into neutral while stopped, i have to be rolling slightly to pop into neutral. The pull i am experiencing is rather considerable, its able to get up to a good speed if i keep it going. Now that you mention it it does feel like the motor is at a higher rev for my normal speed of 65 on my commute to work. this is my second bike and the first time ive had issues with the clutch so i do appreciate your input, and i am open to any other ideas. How far out exactly does the friction zone start when you release the clutch lever? Also, does the clutch slip under hard accel in 5th or 6th gear? It's hard to trouble shoot over the net but it sounds like the only plausible explanation is the clutch cable adjustment being way out of wack.
gsxwetodddid
Post by gsxwetodddid on Nov 7, 2017 17:17:07 GMT -7
The friction zone is about where you would normally want it, about a 1/2 from the handle being released. To be honest I don’t do a lot of hard accel from 5-6th, too much wind...I do a lot in 4th, I don’t feel any slipping occurring. But I am constantly having issues from 1 to 2 and back down, either missing 2nd completely or it will catch and lerch.
superspirit
Post by superspirit on Nov 7, 2017 18:09:44 GMT -7
That sounds more like a trans/shifter problem to me. Is the clutch fully releasing?
Post by Deleted on Nov 8, 2017 6:38:03 GMT -7
gsxwetodddidWhen the shop adjusted the clutch, do you know if they removed the clutch cover on the motor? If you're not sure I can help you if you take a few pics. On the right side of the motor is a large round case. At the bottom of the case is a small arm that the clutch cable attaches to. If you can get under the bike and take a photo (with flash) of the arm and post that it would be helpful. There is an index mark at the bottom of the clutch cover. The center of the arm must be lined up with the index mark. If this part was not installed properly the clutch may not fully disengage, even if you have the cable adjusted correctly. Download the service manual and take a look at the diagram on the top right of pg 5-59. You want to take that photo, under the bike, looking up at the bottom of the clutch cover.
gsxwetodddid
Post by gsxwetodddid on Nov 10, 2017 5:25:01 GMT -7
SO i dropped my bike off at my buddys shop, they took a look at it and turns out that it was a combination of things, first some of the fiber rings were damaged and are need to be replaced. the second issue was the plate seat and cushion spring were wore and stuck together.
I could technically take the bike home with out those rings and wait until the fibers come in, but i read some things online that it would not be the same and there is no guarantee that the clutch wont fail. so i decided to replace the plates with an EBC Carbon kit. Since i am a commuter and not very hard on my bike i think i will get more than 20,000 miles out of the new clutch set. I will post a photo of the worn plates and the other rings as soon as they get out of the bike.
