guywithfz10
Post by guywithfz10 on Sept 29, 2017 19:49:15 GMT -7
As title states, anyone know if I have to drain the engine oil before replacing the alternator case cover?
mattjohnson491
Post by mattjohnson491 on Sept 29, 2017 20:01:06 GMT -7
give me a sec, Ill check the service manual
mattjohnson491
Post by mattjohnson491 on Sept 29, 2017 20:14:40 GMT -7
guywithfz10
Post by guywithfz10 on Sept 29, 2017 20:16:28 GMT -7
mattjohnson491
Post by mattjohnson491 on Sept 29, 2017 20:29:26 GMT -7
Thank you!No problem, including manuals so you can double check me... im not the best mechanic lmao
Post by RedAndBlack on Sept 29, 2017 20:31:00 GMT -7
I replaced a stator one time on another bike and didn't need to replace the oil. Just checked it after to top off. Probably the same for the alternator? The oil sits in the oil pan when the engines off. Only stuff in the alternator should be residual oil.
csmith52016
Post by csmith52016 on Mar 28, 2019 12:03:24 GMT -7
I am trying to find a replacement generator cover. Where did you find yours?
redgecko59
Post by redgecko59 on Mar 28, 2019 13:10:00 GMT -7
Shouldn't need to drain the oil I don't believe
