warnock
Post by warnock on Sept 27, 2017 18:39:54 GMT -7
Is there any trick to using the auxiliary port? I have plugged in two different chargers and they both didn't work but work in my car. I'm not sure if my port is broken or not. I didn't try using it until recently. Thanks
baron
Post by baron on Sept 27, 2017 18:57:10 GMT -7
sounds like a question for the service dept. use mine every ride and it has worked with all 3 things I have plugged in. could be a fuse or the guy that assembled the bike forgot to make a connection.
mattjohnson491
Post by mattjohnson491 on Sept 28, 2017 16:11:03 GMT -7
are you talking about the 12V port?
warnock
Post by warnock on Sept 28, 2017 16:37:36 GMT -7
are you talking about the 12V port? Yes
mattjohnson491
Post by mattjohnson491 on Sept 28, 2017 16:38:56 GMT -7
are you talking about the 12V port? Yes Yes mine works just fine. Sounds like you have a wiring issue
mat
Post by mat on Sept 28, 2017 16:56:29 GMT -7
On mine, I blow the fuse on 1st use. You should check that. Owner manual will guide you.
