loopme1
Post by loopme1 on Sept 23, 2017 17:49:12 GMT -7
Does anyone know these? I have to replace my oil pump cover for... reasons ππ
mrhix
Post by mrhix on Sept 23, 2017 18:38:01 GMT -7
The cover held on by 4 screws? 10 N-m or 7.2 lb-ft.
Cheers,
MrHix
loopme1
Post by loopme1 on Sept 23, 2017 22:37:07 GMT -7
For some reason I thought there were 5 screws π€ The case cover with CP4 on it-
mrhix
Post by mrhix on Sept 24, 2017 6:02:23 GMT -7
So you are talking about the timing chain cover on the right side? 5 bolts @ 12 N-m or 8.7 lb-ft.
The oil pump is accessed by removing the oil pan.
Cheers,
MrHix
loopme1
Post by loopme1 on Sept 24, 2017 7:08:29 GMT -7
This part: # B67-15416-00-00
mrhix
Post by mrhix on Sept 24, 2017 9:01:10 GMT -7
That is not the oil pump cover, even though the parts diagram says so. The oil pump is at the bottom of the engine and is accessed by removing the oil pan.
The service manual lists the side case as the timing chain cover and uses the torques from my second post.
Cheers,
MrHix
loopme1
Post by loopme1 on Sept 24, 2017 9:03:04 GMT -7
Thank you for bearing with me on this haha. I appreciate it!
mrhix
Post by mrhix on Sept 24, 2017 14:13:23 GMT -7
No problem! I've dropped several "things" down timing chain towers.
MrHix
robert23
Post by robert23 on May 28, 2023 5:26:13 GMT -7
Does anyone know the part number for the oring that goes in the top of the timing case cover? Itβs where the bolt goes in the top of the cover. I just dropped my new mt10 and ordered a new cover and gasket however I canβt find the part number for the oring where the line goes into the cover.
robert23
Post by robert23 on May 28, 2023 5:31:18 GMT -7
Post by parthz8 on May 28, 2023 7:25:05 GMT -7
Is this what you are looking for? Oil Pump breakdown for MT-10 under 29:
robert23
Post by robert23 on May 28, 2023 8:22:00 GMT -7
I just need to find out the part number for the oring that goes into the cover.
