jayroc
Post by jayroc on Apr 1, 2017 17:12:50 GMT -7
Something off with the tuono dyno numbers,google search showed 153 to cycle worlds 165hp. I would get your bike dynoed elsewhere.
Post by Cruizin on Apr 1, 2017 17:14:13 GMT -7
Anyone take their bike to a local dyno after 2WD flash? Just did mine today, got 136 HP, 69 TQ (dynojet model 250i) I have Nels flash (from Feb 10th), 3/4 Remus exhaust (DB killer removed) & link pipe, AIS blocked-off, EXUP removed. What I'm kinda concerned about is how lean it's running, so was curious if others had independent dyno sheets so I could compare results. I'll also add the throttle response is slightly more snatchy than stock, not sure if the Feb 10th flash was before the "Stoltec throttle maps" were added or if that's an entirely different flash. For reference, similar modified bikes on the same dyno (different day): 2015 S1000R - 146 2013 Tuono V4R - 138 2015 R1 - 168 2wheeldynoworks Thats a stock hp number, everyone else is getting at least 8-12 hp from Nel's tunes. Alot of people getting 148-149 with the right exhaust. Could it be the Remus dragging it down or have they calibrated their dyno lately? Nel's tunes have been much higher than that for every fz-10 Ive seen so far. Have you called Nels?
pancake
Post by pancake on Apr 1, 2017 17:37:57 GMT -7
I honestly haven't seen anyone else post their own independent dyno numbers, mostly just people showing what 2WD and other shops post. I'm just providing my findings/review, hoping for other real-world Dyno charts from members here and not what people find from a google search. I'm at higher altitude, ~3600 feet, so that I'm guessing would play a into it, it's also just a flash and not a dyno tune...also understanding every dyno will have slightly different results. I don't think there would be any noticeable difference with 3/4 exhausts if you have a link pipe and no silencer in your slip-on, it's essentially open pipes at that point. Mostly want to see peoples A/F if they are also in the 14+ range. For comparison kicks, here's the chart of HP numbers from a Dyno Day June 2016.
latte
Post by latte on Apr 1, 2017 18:07:16 GMT -7
Here is my dyno. I'm about 5hp below advertised and extremely rich. AFR at the bottom. The argument can be made that dyno hp numbers can differ dyno to dyno but the AFR does not lie. I ended up purchasing a Rapid Bike fuel management system as well as the Can-Bus My Tuning unit (wide ratio O2 since 2WDW flash disabled the stock O2 sensors). The Rapid Bike system has AFR auto tune and to get to a true 13.2 AFR it's removed as much as 17% of fuel in some parts of the rev range. I can honestly say that the bike runs even better not running so rich, the top end pulls all the way to the limiter stronger than before. I used to get 80-90 miles to the tank, but after correcting the fuel I'm at 110 miles before hitting reserve. I plan to be on the dyno again in a couple weeks to see the difference in power and AFR. My honest recommendation for folks looking to reflash- get 2WDW to unlock all the goodies like lower fan temp initiation and removing factory limitations, but keep the stock fuel map and even O2 sensors, and then run a Rapid Bike, which will use the stock O2 sensors and autotune your bike's AFR to what you want (for example 13.2) regardless of what mods you have. It'll account for elevation, temp, exhaust, airbox mod, etc. Don't take my post as anything negative towards the 2WDW flash. Nels is a good guy who does a great flash, but short of a fuel controller with auto tune (bazazz, power commander, rapid bike) or having *your* bike tuned on the dyno, a mail-in tune built off the same model bike across the country will only get your fueling so close since every bike is different. For many, the reflash alone will suffice if it's "close enough" but I encourage y'all to get a pull in on the dyno to see how close you get to a proper AFR or power figure.
harry76
Post by harry76 on Apr 2, 2017 6:32:48 GMT -7
UNDERSTAND AFR VALUES:
AFR Values & Characteristics in Four Stroke Engines
6.0 AFR - Rich Burn Limit (engine fully warm)
9.0 AFR - Black Smoke / Low Power
11.5 AFR - Best Rich Torque at Wide Open Throttle
12.2 AFR - Safe Best Power at Wide Open Throttle
13.3 AFR - Lean Best Torque
14.6 AFR - Stoichiometric AFR (Stoich)
15.5 AFR - Lean Cruise
16.5 AFR - Usual Best Economy
18.0 AFR - Carbureted Lean Burn Limit
22.0+ AFR - EEC / EFI Lean Burn Limit
pancake
Post by pancake on Apr 3, 2017 7:22:34 GMT -7
Thanks harry76, my understanding is when doing a dyno run, you are WOT, meaning your graph should target ~12.5-13.5 AFR readings. Mine is in the 14-14.5 in the lean range during WOT. I'm not overly concerned about it, again just curious what other 2WD folks are seeing on their local dyno run sheets. Interesting to see latte was incredibly rich! Just the opposite to mine. (so many variables to consider) I really wish I did a stock baseline run...but I was too impatient over the winter with my upgrades And since the ECU is now locked to 2WD, I might actually do a road-trip ride down to 2WD in the summer to get them to do a proper tune on my bike. They really are great guys to deal with. Shipping it from Canada<->USA is a pain in the butt...had to do it twice already since the first flash broke the cruise control...the $ for shipping and having customs take their time (2-4 weeks) figuring out what to do with the ECU.
pancake
Post by pancake on Apr 3, 2017 7:32:59 GMT -7
...short of a fuel controller with auto tune (bazazz, power commander, rapid bike) or having *your* bike tuned on the dyno, a mail-in tune built off the same model bike across the country will only get your fueling so close since every bike is different. Ya I'm going to look at getting one of these...maybe the FTECU one.
latte
Post by latte on Apr 3, 2017 11:22:09 GMT -7
Thanks harry76, my understanding is when doing a dyno run, you are WOT, meaning your graph should target ~12.5-13.5 AFR readings. Mine is in the 14-14.5 in the lean range during WOT. I'm not overly concerned about it, again just curious what other 2WD folks are seeing on their local dyno run sheets. Interesting to see latte was incredibly rich! Just the opposite to mine. (so many variables to consider) I really wish I did a stock baseline run...but I was too impatient over the winter with my upgrades And since the ECU is now locked to 2WD, I might actually do a road-trip ride down to 2WD in the summer to get them to do a proper tune on my bike. They really are great guys to deal with. Shipping it from Canada<->USA is a pain in the butt...had to do it twice already since the first flash broke the cruise control...the $ for shipping and having customs take their time (2-4 weeks) figuring out what to do with the ECU. I sent my ecu in twice because I had a stumble when cracking the throttle open and Nels was able to mostly remedy it by adding a little more fuel. My afr therefore may be a little richer than others. Every bike is different, I know a guy with the same tune and he had no stumble whatsoever.
mikem73
Post by mikem73 on Apr 14, 2017 17:19:04 GMT -7
The best upgrade that I have ever done to any bike I have owned. Clearly makes the bike run better and smoother just exactly like it should. Thanks 2WDW everyone from now that I come across that is wanting to better their bike I will be sending your way!
tonysal
Post by tonysal on Apr 20, 2017 10:18:48 GMT -7
pancake, latte, harry76;
thanks for the great information/discussion...
need to get my bike on a dyno for a run.
regards, Tony
Post by slv on Apr 22, 2017 12:05:24 GMT -7
Interesting numbers. The 136 value is low compared to Nels' tune with the stock muffler and just a link pipe. It seem strange that the tuner you used didn't squeeze more out of it (unless you only paid for a measurement of course.)
It may be worth asking Nels his opinion, and maybe getting it re-flashed.
pancake
Post by pancake on Apr 23, 2017 9:13:12 GMT -7
Interesting numbers. The 136 value is low compared to Nels' tune with the stock muffler and just a link pipe. It seem strange that the tuner you used didn't squeeze more out of it (unless you only paid for a measurement of course.) It may be worth asking Nels his opinion, and maybe getting it re-flashed. I just did a local Dyno baseline after having Nels flash, just to see what the #'s were and mostly the A/F ratio.
mrhix
Post by mrhix on Apr 23, 2017 17:04:20 GMT -7
Has anyone checked their OBD connection to see if it works after their flash? I have a flash from 2WDW last week and no luck connecting my code reader (Autel 519) to the bike.
Thanks,
MrHix
pancake
Post by pancake on Apr 25, 2017 7:13:11 GMT -7
Interesting, I don't have a reader yet so I can't check mine but I did ask Nels if the diagnostic port issue was also fixed when I sent my ecu back (~Feb 1st) to have the cruise control fixed and he replied: "Yes. 100%."
danyboy24
Post by danyboy24 on Apr 26, 2017 11:50:12 GMT -7
Same thing here...my ODB does not work with flash 2wheeldyno (flash dated January 2017)
mrhix
Post by mrhix on Apr 26, 2017 13:27:53 GMT -7
Same thing here...my ODB does not work with flash 2wheeldyno (flash dated January 2017) Thanks danyboy. MrHix
Post by Deleted on Apr 30, 2017 20:25:48 GMT -7
I ran about 300mi today with the 2WDW flash. I have removed the O2 sensors, the EXUP eliminator plug, and the remaining AIS hardware and have no codes.
Here's my feedback. I'm really interested to hear if others' experiences are similar.
Mileage and Power -Idle is smoother and a little quieter -Absolutely no exhaust pop. It would happen periodically before. -Cruising mileage remains around 36-39mpg on flat ground at 65-75mph -Mileage nosedives when revs are up. I'm usually not hard on the throttle and not a wheelie popper either. -Average MPG is down to 31-32 from 34-35. -Engine temps remain the same as before when moving. Fans come on sooner when stopped. -Power comes on smooth but is not eye popping. I'm not really feeling the +14HP. It has been a week since I rode this bike and I know smooth power can mask an increase. Without a dyno I can't be sure of what the actual output is. -I feel a loss of low-mid range torque. The bike seems to struggle if throttle is opened under 5000rpm. I used to be able to open it up in 6th on the highway and it would pull.
Throttle Modes -Before the flash I preferred A mode. I felt that Std was way too lazy and B was a bit twitchy. -Post flash, Std is useful. Response is softer than A and B modes but is usable. A good option in the rain and gravel perhaps. -A mode feels more like the old B mode. On rough roads it is hard to modulate throttle smoothly. -B mode is more forgiving and I feel it allows easier modulation of small throttle inputs. This is where I did most of my riding.
guywithfz10
Post by guywithfz10 on Apr 30, 2017 20:39:00 GMT -7
I ran about 300mi today with the 2WDW flash. I have removed the O2 sensors, the EXUP eliminator plug, and the remaining AIS hardware and have no codes. Here's my feedback. I'm really interested to hear if others' experiences are similar. Mileage and Power -Idle is smoother and a little quieter -Absolutely no exhaust pop. It would happen periodically before. -Cruising mileage remains around 36-39mpg on flat ground at 65-75mph -Mileage nosedives when revs are up. I'm usually not hard on the throttle and not a wheelie popper either. -Average MPG is down to 31-32 from 34-35. -Engine temps remain the same as before when moving. Fans come on sooner when stopped. -Power comes on smooth but is not eye popping. I'm not really feeling the +14HP. It has been a week since I rode this bike and I know smooth power can mask an increase. Without a dyno I can't be sure of what the actual output is. -I feel a loss of low-mid range torque. The bike seems to struggle if throttle is opened under 5000rpm. I used to be able to open it up in 6th on the highway and it would pull. Throttle Modes -Before the flash I preferred A mode. I felt that Std was way too lazy and B was a bit twitchy. -Post flash, Std is useful. Response is softer than A and B modes but is usable. A good option in the rain and gravel perhaps. -A mode feels more like the old B mode. On rough roads it is hard to modulate throttle smoothly. -B mode is more forgiving and I feel it allows easier modulation of small throttle inputs. This is where I did most of my riding. I noticed the biggest power difference in the ~4.5k-5k rpm range where the bike responds immediately to throttle input and takes off even in std mode. Before the flash, it felt like it was a flat spot in the power band around that rev range and would take a bit for the power to come on. And once I'm up in the 9000 - 11000 rpm range I'm just holding on for my life because it just hauls like a freight train. I'm curious about what you said regarding loss in low-mid range power. I felt that was where the bike had the biggest gains and I have no problem passing people on the highway in 6th gear just rolling on the throttle. I wonder how others feel.
Post by Deleted on May 1, 2017 12:09:52 GMT -7
So on my commute today on more familiar roads I was able to test out some more.
At 4-5000rpm, low throttle inputs create some motor vibration until revs pick up. If I whack it open it just takes off. Maybe this is how its supposed to be and I'm misinterpreting the vibration as bogging?
And yes, at higher revs it is flying but its kind of hard to guesstimate if its faster than before because I never really ran it wide open to begin with.
Post by 0002s on May 1, 2017 15:06:37 GMT -7
Your butt dyno is messing with you.
