Post by Deleted on Feb 22, 2017 6:00:27 GMT -7
That was the easiest ECU to get at of any bike ever!!! LOL
Nels at 2wheeldynoworks should have my ECU tomorrow.
Ready to remove the O2 sensors when the ECU gets back.
warnock
Post by warnock on Feb 22, 2017 9:47:51 GMT -7
Where did you get the plug connectors for the female side of the 02 sensors which you disconnect? Do I need them or can I just tape them off or something else?
Post by Deleted on Feb 22, 2017 11:13:13 GMT -7
Where did you get the plug connectors for the female side of the 02 sensors which you disconnect? Do I need them or can I just tape them off or something else? I will have to look for the link when I get home tonight but yes you could just tape them
Post by slv on Feb 22, 2017 12:56:04 GMT -7
Post by slv on Feb 22, 2017 14:33:39 GMT -7
Be patient with the right side connector. It's a pain in the ass, but doable with patience and a steady hand. I used extended needle-noze pliers to hold the connector, and a small screwdriver to detach the tab.
Remember.... Lift the tab to release it. Pushing in on the tab does nothing but create frustration.
spartanadv
Post by spartanadv on Mar 3, 2017 19:25:27 GMT -7
Just removed the servo, what is this thing that says up? Also, about to remove the O2 sensors. Preparing for the ecu to return.
Post by RedAndBlack on Jul 23, 2017 15:37:42 GMT -7
Just a heads up for anybody else that stumbles upon this. Obviously $20 for some glorified bolts is too much. I also felt that the 20 mm long thread is too long for this application (you'll have some of the bolt thread sticking into the exhaust and ob structing air flow) and I couldn't find a local hardware store that stocks a M12-1.25 bolt with less than a 25 mm long thread in stainless steel. Did some research and found the following drain plug designed for Nissan's. Just Google part # 653056. It is an M12-1.25 bolt with a .7 inch thread (~10 mm). It also comes with a crush washer. I installed it, everything fit fine and went on a good canyon ride today and everything appears fine. I was concerned with the crush washer since it's some other material, but it held up fine to the exhaust temps. $4.99 each (obviously you need two). Not as good of a deal as operationfz was able to find, but for just over $10 with tax, thats half of the Vance & Hines one or of anything else I could find that was advertised as an O2 sensor plug. I was able to pick them up at my local AutoZone. They were in stock, didn't even need to order them for me. EDIT: I wound up losing one of the bolts. Not sure if I just didn't tighten it enough. The plugs are steel, thought they would stand up to the heat fine. Anyway, I tightened them down much harder this time and used red locktite. I think red locktite is good for like 400-500 degrees so hopefully it stands up to the heat. I did also drill and safety wire the bolts so they won't go anywhere this time. But I felt it was fair to update this thread that my recommendation might require you to really torque the bolts down and use locktite. I'm pretty confident they are secure enough now, but with the red locktite and over torquing them, they may be a huge pain in the ass to get off in the future if you ever wanted to. www.autozone.com/external-engine/engine-oil-drain-plug/needa-parts-engine-oil-drain-plug/257247_339497_0
Post by achrista on Jan 4, 2018 19:44:29 GMT -7
Took out the ECU tonight. When I lifted up the lever to remove the ECU from the harness (wasn't exactly easy) I heard a snap and a small plastic bit came off. The lever seemed to function properly so I am hoping it's just a piece that breaks off the first time the ECU is taken out so dealers can tell if it's ever been removed. Is this accurate or should I start worrying and figuring out precisely what broke.
Post by heathhudnall on Jan 5, 2018 7:20:39 GMT -7
Took out the ECU tonight. When I lifted up the lever to remove the ECU from the harness (wasn't exactly easy) I heard a snap and a small plastic bit came off. The lever seemed to function properly so I am hoping it's just a piece that breaks off the first time the ECU is taken out so dealers can tell if it's ever been removed. Is this accurate or should I start worrying and figuring out precisely what broke. I wouldn't worry to much. I noticed that when I removed mine there was a tab that I had to press that acted as a "lock" to ensure the lever was inadvertently raised.
sam07
Post by sam07 on Jan 5, 2018 7:40:33 GMT -7
No plastic pieces should break when lifting the lever. You may have broken the lock. If the housing is in good shape and the lever works, electrical tape is your new lock....
Post by achrista on Jan 5, 2018 11:35:33 GMT -7
well there's my first blunder on the MT. I didn't see a lock tab so I'm certain that's it. I am thinking electrical tape should be sufficient, but I'll update if i come up w/ anything else.
ccm182
Post by ccm182 on Feb 11, 2018 2:54:32 GMT -7
I about did the same thing. I didn't even notice the center tab to push down. Maybe the OP can add in to push in that center tab in the picture?
Post by deftone on Mar 10, 2018 17:45:58 GMT -7
Nice, I plan to do the same. is this what you used to plug the O2 sensor holes? Nels has them as well. Save your self some time & $ and order the block off plates, and the o2 removal kit from 2WDW when you get your re-flash. Nels can send them all to you in one convenient package.
dewaynehasty
Post by dewaynehasty on Mar 19, 2018 17:37:40 GMT -7
I'm curious as to why to remove O2 Sensors? Does the ECU flash also renders the O2 Sensor useless? It was explained to me by Nels that it allows more control over the fueling and the ability to smooth out the bike.
I talked to Nels few days ago. I was asking why after having the flash I still had such heavy engine braking which gave the feeling of on/off throttle response. He told me to disconnect the O2 sensors and that should smooth it out. I disconnected them as he suggested. After two days of riding I can say that it made a huge difference on smoothing out the throttle and reducing the heavy engine braking.
raven
Post by raven on May 13, 2018 13:19:55 GMT -7
Just a quick add. Using the blank plug, I filled the wire tubes with high temp silicone and plugged them into the open connectors that were left on the bike. img hostThank a lot for putting this altogether. One question, can you get that wire plug anywhere to cover the "male" plug?
raven
Post by raven on May 13, 2018 14:49:43 GMT -7
Haha...disregard, saw the posts about connector. Now, just trying to get to the right side plug.
paulb63
Post by paulb63 on May 13, 2018 17:15:49 GMT -7
Just a quick add. Using the blank plug, I filled the wire tubes with high temp silicone and plugged them into the open connectors that were left on the bike. img hostThank a lot for putting this altogether. One question, can you get that wire plug anywhere to cover the "male" plug? You can get the rubber bungs to plug the holes when you buy the plug. easier than the silicon option...
raven
Post by raven on May 23, 2018 22:02:45 GMT -7
Thank a lot for putting this altogether. One question, can you get that wire plug anywhere to cover the "male" plug? You can get the rubber bungs to plug the holes when you buy the plug. easier than the silicon option... Thx. I'm hoping to have this done this weekend but still need to get the wire plug. For now probably just wrap it with electrical tape.
Post by Deleted on May 24, 2018 4:07:04 GMT -7
I had no intention of reusing the stock O2 sensor so I removed the wires and filled the connectors with silicone. It takes about 5 minutes of your time. I don't have any pictures, but there is a metal tab that you need to slide over and then pull the correct wire. They will release without issue.
tangogun
Post by tangogun on Jun 8, 2019 7:00:02 GMT -7
Ummmmm wth? How do I unroute that? I can't even get to the connector up top. <a href="https://ibb.co/X8YrVPm"><img src="https://i.ibb.co/fvDzQWm/20190607-204248.jpg" alt="20190607-204248" border="0"></a> <a href="https://ibb.co/VVfPRpg"><img src="https://i.ibb.co/rkD1Yfx/20190607-204234.jpg" alt="20190607-204234" border="0"></a>
