vullnet
Post by vullnet on Jul 31, 2021 9:13:35 GMT -7
forceflow17
Post by forceflow17 on Jul 6, 2023 22:19:44 GMT -7
157, GPS speedo. Akrapovik cat delete, Puig touring screen and stage one brentune from BT Moto. Wasn't hitting the limiter yet, rolled off before cresting a blind hill. I'm 225lbs, and in CO so riding at elevation.
bbeem
Post by bbeem on Jul 25, 2023 5:14:37 GMT -7
Gets to 150 quick where 5th tops out then slower to 160, 161. It gets up to 160 every time but it's hard to wring out much more. 163 takes another half mile and 166 another mile if you've got a big downhill and tail wind. Seems like 6th would do 175 factory gearing but not enough power/aero to get close. The wind isn't too bad with a good helmet and puig sport windscreen. '22 with Austin pipe and 2wdw tune.
vulcanator
Post by vulcanator on Aug 24, 2023 10:29:36 GMT -7
Had an ECU reflash, stock pipe, AIS removal, changed the rear sprocket to a 42 tooth same a 2022 MT, hit 163mph. Might see a little more with the right road.
bbeem
Post by bbeem on Nov 10, 2023 16:23:26 GMT -7
I was able to hit the rev limiter in 6th a few times on a windy day this week. It revved out at 171mph with the increased redline on the 2wdw tune. Usually I top out at 168 without tailwind. Bike has Austin pipe, puig short windscreen and open ram air ducts.
Post by mindcrime79 on Nov 12, 2023 18:55:51 GMT -7
Bike has Austin pipe, puig short windscreen and open ram air ducts. How did you accomplish open air ducts or is this not a 1st gen?
semprenissart
Post by semprenissart on Nov 12, 2023 19:38:52 GMT -7
Bike has Austin pipe, puig short windscreen and open ram air ducts. How did you accomplish open air ducts or is this not a 1st gen? 2nd gen per his message 2 posts above the one you quoted
bbeem
Post by bbeem on Nov 14, 2023 19:21:26 GMT -7
Bike has Austin pipe, puig short windscreen and open ram air ducts. How did you accomplish open air ducts or is this not a 1st gen? Dremeled off the blocking pieces on gen 2
