semprenissart
Post by semprenissart on May 8, 2023 18:42:13 GMT -7
UPDATE to my issue
Yamaha sent me new grip warmers under warranty and everything works properly now!
larsony99
Post by larsony99 on May 8, 2023 19:19:13 GMT -7
larsony99Were you able to try it? Also any idea if the voltage drop on the connector in the video I posted over is normal ? Hey, sorry for taking so long. Even with just one grip connected, I had functionality of the grips on my dash. It showed up on the main screen and I could access the settings in the menu. It even turned on, although I didn't have the engine running since my son is asleep already. I'm not sure about voltage drop, but I think you may need to RMA and replace your grips.
larsony99
Post by larsony99 on May 8, 2023 19:19:41 GMT -7
UPDATE to my issue Yamaha sent me new grip warmers under warranty and everything works properly now! Dang. I was so far behind. I'm glad it's all working for you now though lol.
platinumt10
Post by platinumt10 on May 25, 2023 2:28:18 GMT -7
Where under the screen? I took off the screen, the mount, and the plastic piece and all I got to was the turn signal wires and the back of the dash. Do I need to take off more? these should be the heated grip wires not the turn signal wires unless we're not talking about the same thing? If you post a picture of it, I'll show you which connections exactly. How did you get the plastic piece under the windscreen off . I removed the bracket..
platinumt10
Post by platinumt10 on May 25, 2023 6:47:53 GMT -7
I got mine off eBay Australia, if anyone is still trying to find heated grips. I took off the windscreen and the bolts with bracket, how do I get the plastic piece off , not sure where to pull or if there are hidden bolts?
larsony99
Post by larsony99 on May 25, 2023 7:07:31 GMT -7
I got mine off eBay Australia, if anyone is still trying to find heated grips. I took off the windscreen and the bolts with bracket, how do I get the plastic piece off , not sure where to pull or if there are hidden bolts? The last plastic piece just has friction fittings. You just pull on it. If you need some leverage, use a plastic trim removal tool. There should be I believe 7 bolts total; 4 on the screen and 3 on the bracket.
semprenissart
Post by semprenissart on May 25, 2023 15:07:45 GMT -7
I got mine off eBay Australia, if anyone is still trying to find heated grips. I took off the windscreen and the bolts with bracket, how do I get the plastic piece off , not sure where to pull or if there are hidden bolts? Like said above, if you removed the 7 bolts, the last plastic piece just need to be pulled to remove it. It looks like an upside down triangle. Start with the bottom part then the 2 other ends on the top. It needs a bit of force but they don’t break easily. I’ve removed them plenty of times and never had an issue
motorman
Post by motorman on Jul 28, 2023 6:20:44 GMT -7
Try calling Kelly’s cycle centre in Hamilton ont. They are the fulfillment centre for the Yamaha website in the Toronto area They might ship to the U.S. 1-585-237-2757 Just wanted to update this post with the correct contact info as i see the phone # listed is wrong...its 905-385-5977. Yes these guys are a Yamaha only dealer and do sell all the Yamaha Accessories including the Heated factory grips. Bought my bike form them
northsouth
Post by northsouth on Jan 9, 2024 16:59:03 GMT -7
That’s the place I ordered mine from. Arriving tomorrow!
northsouth
Post by northsouth on Feb 3, 2024 7:30:28 GMT -7
Plug and play. No issues and they work great!
