Post by mt10orc on Apr 18, 2023 20:34:08 GMT -7
Thanks for the update man. Love watching ur progress.
skameigh
Post by skameigh on Aug 29, 2023 18:57:32 GMT -7
Just installed this kit as well. Bike is at the dyno right now getting tuned. Let's see if my stock motor can handle it any better. Don't really want to do a rebuild yet lol.
Post by Deleted on Aug 30, 2023 5:23:52 GMT -7
Dang!
How much boost do you plan on running? What kind of hp are you tuning for?
skameigh
Post by skameigh on Sept 1, 2023 5:25:32 GMT -7
Dang! How much boost do you plan on running? What kind of hp are you tuning for? Just running wastegate pressure which is around 7psi of boost I think. I want to install a boost gauge to verify this as the tuner thinks it may only be seeing 5-6psi. I didn't do a leak check prior to tuning so its possible I have a slight leak. After dyno tuning, we ended up at 192whp 95wtq. The graph is incredibly linear and the bike feels so smooth. It honestly doesn't even feel like a turbo bike and you can't hear it at all. To me it feels like a stock bike but with more hp. It's incredibly fun to ride. It power wheelies so easily if that's your thing. The turbo is so smooth that when it does power wheelie, it's very controllable. The turbo was sized perfectly for the bike. No lag at all! We removed 3 degrees timing from stock map and kept fuel at 11.5 afr while under boost. We probably could have picked up a few more hp if we took another degree of timing out but since this bike is my daily, we kept it more conservative.
skameigh
Post by skameigh on Sept 1, 2023 5:34:03 GMT -7
Post by willl84 on Sept 1, 2023 10:03:44 GMT -7
That chart looks buttery smooth. R1 HP but with more torque lol
Post by mt10orc on Sept 1, 2023 18:21:45 GMT -7
That is freaking awesome. Looks like the wife’s bikes chart. Nuts!
darksideofjapan
Post by darksideofjapan on Mar 19, 2024 22:40:11 GMT -7
Does it fit the 2nd Gen mine is 2023 I would love to unleash the beast with this kit but I’m a bit concerned with the fit meant
Post by willl84 on Mar 20, 2024 5:30:24 GMT -7
Does it fit the 2nd Gen mine is 2023 I would love to unleash the beast with this kit but I’m a bit concerned with the fit meant I didn't see anything on their website saying for sure but I would assume so as nothing changed much. You might have issues with the air intakes as the second gen is way different from the first.
